Radio interference
Old Dec 16, 2016 | 03:18 PM
Roys92BlackRose's Avatar
Roys92BlackRose
Default Radio interference
Funny thing about my 92 coupe. It's parked in the garage and my DD is outside. I use the garage remote in my DD to enter the house usually. When I take the Vette out, I grab the remote from my DD and hop in the Vette. After I back out, the remote won't work. It works perfectly in the DD. When I shut the Vette motor off, the remote works. Any ideas?
Old Dec 16, 2016 | 03:23 PM
BLUDICE's Avatar
BLUDICE
Was there a "full" moon that day/night??
Old Dec 16, 2016 | 10:34 PM
Klondike's Avatar
Klondike
When you put your radio to a non-station area on AM do you get a motor buzz on your radio?
Old Dec 16, 2016 | 10:56 PM
Roys92BlackRose
I don't listen to the radio, I use a USB stick in a Kenwood deck.
But I'll check that at my earliest convenience.
What if I do get a buzzing?
Old Dec 17, 2016 | 12:10 PM
Klondike's Avatar
Klondike
If you get a buzz or a fast "pop-pop-pop" that increases with rpm, there's a good chance you have a bad spark-plug wire with a spark gap break in it. Bad wires will burn themselves out from the inside until the gap gets wide enough to either not fire the plug any more (miss) or it will arc through the wire to some place on the engine; another miss but you'll probably be able to hear the snap of the spark with the hood open.
Old Dec 17, 2016 | 12:45 PM
BLUDICE's Avatar
BLUDICE
Does the remote work or not work with the inigtion "on" but engine not running??
Old Dec 17, 2016 | 12:51 PM
Roys92BlackRose
I haven't tried it with just the ignition on. I usually just turn the key to the off position.
Old Dec 17, 2016 | 01:00 PM
BLUDICE's Avatar
BLUDICE
You might want to try several test to get a clue of what's happening. Is the interferance from the electrical or motor, or??
Old Dec 18, 2016 | 02:25 PM
pcolt94's Avatar
pcolt94
Try different configurations to narrow down what may be causing it. Listen to your AM radio to see it there is excess static noise or whine in it.
Did you check the battery in the remote? Just to be sure.
To Radio interference
