Its a 1985 75,000 miles, asking price $4500, owned by a little old man who only used it to drive to church. Garage kept. All 4 tires are good [ shocker ]
Has those 80s turbine rims that I want, no really. [ just need a "Spencer Gifts" satin Vette jacket to wear when I drive it. ]
Looks gold but someone said that's actually bronze, don't know?
besides its 2 month to early for good driving weather in NW Ohio, any thoughts or suggestion to check out before I hand over the cash?
A C4 is like any used car, so watch for oil/ fluid leaks, take note of the condition of the fluids, take it for a test drive, make sure the engine runs well, transmission can go into all gears properly, etc...
As far as C4 specific stuff, check to make sure the headlights go up and down properly, power antenna goes up and down, pay special attention to the interior as those components are expensive so for each thing that is broken or worn you will be spending money If you want to fix the issue. When you close the door watch to see if the door panel shakes as broken door panels are very common on C4's. Also pay attention to the condition of the weather stripping as most C4's will need new weather stripping if it has not already been replaced. One other thing is check that the wheel bearings don't have too much play as that is a common C4 problem also.
There is probably a few other things but that's all I can remember right now, hope that helps.
Add to the list: instrument cluster and paint. Instrument cluster can be repaired if not working but paint can be expensive to take care of.
One thing of note is early C4's (which include this one) have a different size and offset rim. There are options but few and far between.
If it's a manual trans, check the overdrive unit for proper operation.
Check the condition of the various bushings in the suspension. They are replaceable but takes some time.
Some people used the steering wheel to pull themselves out of the car. Check it out for play. It can be fixed in some cases or replace the column to repair it.
Look for frame or body repairs.
Check compression on the engine and condition of fluids.
If it all checks out, $4500 isn't bad for a decent condition 85. You undoubtedly will need some parts and repairs regardless but the better it is to start the better it will be for you.
As with any vehicle of this age, you want to be able to do some of the repairs yourself or you'll go bankrupt over the long run.
I second the weatherstripping comment. Needed to replace all of mine.
Check the carpeting on the passenger side. If there's moisture or water on the carpet, weatherstripping or cowl drains cloggedThis can cause interior odors if wet for long.
Listen closely when loading up the drive train. A clanking or clinking seems to be a common issue and means u-joints, teflon drive axle washers, or the like. I'm replacing all of those items now.
Backup light switch. Mine was bad, didn't realize until I installed new backup camera. This is in a tough location and you need to raise it on a lift to replace.
Even with these issues, I am still having a blast working on this car. Most fun I've had since I was in my late teens. Great driving too. You'll love it!
I know you say the tires are good but what year were they made? There are a lot of old but good looking tires out there, they're not safe and ride like crap. The same with belts and hoses, brake hoses. Sounds like a good price but still plan on bringing the maintenance items up to date.
Gary
Excellent point. As an example, I can tell you that the tires on the current '87 I am working on have less than 500 miles on them but have a 2003 date code. I certainly don't trust them.
So not much use and short distance drive? Not very good for condensed water in the oil pan. 4 good tires? Excellent. Should cost you about $20 for disposal unless you can check the year code and it is recent.
Figure on how much it would take to dump all the fluids. I'd check them for newness. If it is brand new, I'd be leery since the first thing that comes to mind is "what are you trying to hide?". Figure that if it is ok, dump all fluids from the rear end to the radiator. Injectors are probably good for trashcan throwing games. Hoses I wouldn't trust. Belt? See above.
Have you checked compression and done a leakdown test? If not, have a mechanic do those. I'd send the trans fluid off for testing or drop the pan.
In short, look for something that is too new. Few people change stuff when the car is being sold unless they are trying to hide something.
Quote:
Originally Posted by hcbph One thing of note is early C4's (which include this one) have a different size and offset rim. There are options but few and far between.
Originally Posted by Buick350X
IM actually ok on that, I really do want the 80s turbin rims. What has shyed me away from other years in the same price range. It must have them
Course besides rims, were you talking about tires?
I see the factory 255 50 16 there is only 1 brand in that size for street tires. BFG gforce.
Is there another tires size folks goto with more brand options?
Lots of good advice all I'll add is let the engine run while you're checking it out before you test drive it. This way the cooling fans will come on and the fluids will warm up. Then take it for a good ride not around the block. You can see how the car tracks, how the brakes feel, try all the options like the A/C, rear defroster, the power windows and locks watch the dash display and gauges, be observant. A thorough road test may expose negatives that will give you room to further negotiate. Don't forget it's a 30+ year old car so it's going to have needs. Good luck and yes post pictures.
I appologize for the troll () and have since deleted it. I guess you really are interested in this car and it's a real car. By your original comments though, it sounded to me to be someone just "fishing" or "trolling" here with no real car being involved. Good luck in your venture. But do keep in mind that $4500.00 isn't that much money for a Corvette, so don't expect perfection by any means.
Gary
Mine were 12yrs old, and the inused spare was original to the car in 1993!! My buddy runs a tyre depot and recommends no older than 7yrs.
still 2 more days before I get to see it in person, but already shopping for stuff to buy
Being a 85 there is no Vats right?
What kind of security or alarm is desired amongst yall in C4 land???
1 way, 2 way alarm???
Only 1 hitch, I do not want remote start. Which had killed plans to have one installed local. They only sell the full options $500 ones "installed" [ why? my Jeep came with remote start, after the 5th time of starting it when I had no intention of starting it, I removed to key fobs and hide them, as it has a factory alarm ]
