vacuum line
Old Jan 11, 2017 | 05:06 PM
Matthew Hall's Avatar
Matthew Hall
Default vacuum line
c4 corvette with 4+3 transmssion, can someone help me try to verify the vacuum lines going into the correct ports? thank you in advance.. it is on a edelbrock 1406 carb. and mild cam.
Old Jan 11, 2017 | 07:39 PM
DUB's Avatar
DUB
First off the hose that is coming off the breather in your LEFT valve cover (that should be a PCV)...should have that hose going to the FRONT port on your carburetor.
AS for the rest...I do not know or can see what it is you are needing connected due to the photo not being that good. Such as where that hose that is connected to your left valve cover breather is going.
I am lost. We may either need you to draw it up...or let us know what you are needing to be connected. Even if you have to apply white tape with numbers written on them on the hoses so we have a reference point to start from.
DUB
