Bubbling paint question
Old Jan 24, 2017 | 02:48 PM
73n95's Avatar
73n95
Default Bubbling paint question
I know, paint threads are all over the place but hopefully this has not been covered. Mine is a 95, Competition Yellow and its a repaint. Its a pretty good job. It looks exactly like a factory job. The only reason I know its a repaint is there is a bit of overspray in some areas. There is a little bubbling just over the rear wheel arch about midway between the edge and the hatch. Its about 4 inches long and a quarter inch wide. There are no other areas. You can hardly see that it is lifted but its flexible under finger pressure. The finish is flat when it is cool and dry and seems to raise a bit in the sun. Its almost unnoticible. I suspect a bit of adhesion loss, probably due to poor prep. The car is garaged and seldom left in the sun. I'm inclined to leave well enough alone as its not going anywhere and it really doesn't bother me but I'm wondering, can it be repaired without a total repaint?
Old Jan 24, 2017 | 06:17 PM
ls777z's Avatar
ls777z
Default Repaint?
A good body shop shouldn't have a problem but who knows what else they might find when they start stripping the area. If you can live with it, do so. When you can't take it anymore than have it looked at.
Old Jan 24, 2017 | 07:14 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
I'd try to find out who painted it and ask them
Old Jan 24, 2017 | 07:44 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Its almost unnoticible.....I'm inclined to leave well enough alone as its not going anywhere and it really doesn't bother me but I'm wondering, can it be repaired without a total repaint?
If it does not bother you, then leave it alone. If you take it to a painter and have it redone you have that possibility it won't be repaired to your liking and then you'd be really annoyed.
I understand the "It's not bugging me.... but...." syndrome.
Old Jan 24, 2017 | 08:42 PM
Silver85's Avatar
Silver85
Sounds like a definite adhesion problem and the clear is holding it on and together.
I am betting it wouldn't cost too much to fix. A good blending job and you won't even notice it. Not a ton of prep work so it should be fairly quick.
Old Jan 24, 2017 | 09:09 PM
Lt4-396's Avatar
Lt4-396
How much is the paint lifting? Depth wise?
Old Jan 25, 2017 | 03:21 PM
73n95's Avatar
73n95
The lifting is so mild that it looks like a small ripple. Its not a large bubble, but a couple of small ones, 1/4 inch by 1/2 inch or so. Only when I push it with a fingernail can you tell its actually loose. There are no cracks. I thought of taking a fine needle and injecting some sort of adhesive and pressing it down but having never done it it could lead to more damage. I'm thinking its best left alone until it gets worse or cracks. It does not seem to be spreading. I'd post a picture but I'm not sure how to.
Old Jan 25, 2017 | 05:11 PM
Lt4-396's Avatar
Lt4-396
That's exactly where I was heading, if it was lifting pretty bad you can "pop" it and glue it down then put a tiny tiny drop of paint over the little hole and it will last years. Since you can hardly see it I would leave it alone.
To Bubbling paint question
