Door hinges
Old Mar 13, 2017 | 07:42 PM
mlm0's Avatar
mlm0
Default Door hinges
1989. Automatic
does anyone know of YouTube or tech article on how to replace door hinge pins
Old Mar 13, 2017 | 08:46 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
support the door with a jack. removeing only ONE at a time. cut the pin and remove old pin, and old bushings. install new bushings. lube the pin up real well and drive it in the bushings until the splines match the splines in the bushings. repeat in the other hinge
Old Mar 13, 2017 | 09:29 PM
mlm0's Avatar
mlm0
what did you cut pins with and why? Where at on the pin do I cut
thanks
Old Mar 13, 2017 | 09:36 PM
Nowhere Man
I cut the pins with a air cut off wheel. But use what ever you can where you can. You have to becouse the factor swedged the pin at the top
Old Mar 13, 2017 | 10:23 PM
mlm0's Avatar
mlm0
i guess I confused, and don't see the whole picture. I don't understand by cutting the pins, how does that enable me to get pens out if they are swedged in Do I have to make two cuts in each pin to make room for pin to come out upward. Is there room for new complete pin to go back in from top. Looks like inside of door will interfere. I have new pin set coming in tomorrow from rock auto, so I will have a better look at how pin is made
thanks
Old Mar 13, 2017 | 10:28 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
https://www.corvetteforum.com/forums...post1593547744
that's how I did mine. I left my door closed.took off the hinge (3 bolts on door, 3 on body) cut the pin in the center, and pulled the top out the top and the bottom out the bottom.
VikingTrad3r
Oil Producer
I replaced with the doorman kit that has the little retainers.
Old Mar 13, 2017 | 10:43 PM
mlm0's Avatar
mlm0
ok, so need to first take off hinge from door and body, then replace pin. I think I understand now. I thought I was replacing pin with hinge still attached to car. When you put hinge back on, was there any adjustment that had to be made?
Old Mar 14, 2017 | 12:36 AM
BV85's Avatar
BV85
Default Door hinge
mlm0 I would mark the hinge with masking tape that way it goes back on exactly where it was when taken out off. Do the same on the door side. Door close and one at a time. Hope this helps. TIA
Old Mar 14, 2017 | 03:26 AM
VikingTrad3r
Oil Producer
i used a marker.
Old Mar 14, 2017 | 11:10 AM
mlm0's Avatar
mlm0
Thanks everyone
To Door hinges
