I know how to use the Parking brake that's not the issue...
The Issue is I went to apply said brake and my thumb began hurting. Upon Closer inspection, it appears the plastic ****/insert is missing and only the metal tab is sticking out...It kind of hurts to apply the brake and to Un-apply...
I'm looking all over the place and I cannot see if in restoration areas if it's even a replaceable part? Am I SOL? Do I have to grow more callous on my thumb?
Did you look for the button on the floor and under the seat? Maybe go to a junk yard and see if you can find one from another type of car that can be retrofitted. Worst case, should not be hard to get the whole assembly used.
Yeah, I even pulled the bolts from the front seat out and looked under there... Found a name tag for someone named "Will: who apparently worked for Duncan Donuts though....
I found the entire assembly on ebay... lowest price is 150 bucks.... The 84-87 ones are 50 bucks.... the 88-96 ones are 150-200 bucks... Not many junkyards in New England let you just walk around.... But hmmmmmm.... I may know a kid in my Son's Boy Scout troop that has access to a relative's Junkyard... Hmmmmm A mission for him.... Hmmmmmmmm......
Is the button the same on all years ? Can't imagine that piece is Corvette specific...
