Accessory plug
Old Apr 5, 2017 | 11:12 AM
Komiller118's Avatar
Komiller118
Default Accessory plug
Need ideas for 12 volt accessory plug. Need a multi port usb or regular plug that will go in cigg plug
Old Apr 5, 2017 | 11:21 AM
MrJoelieC's Avatar
MrJoelieC
Funny you should ask... I'm considering mounting one of these inside my center console:
Amazon Amazon
Old Apr 5, 2017 | 12:30 PM
Komiller118
I believe my console is wired for one but not sure what to put there
Old Apr 5, 2017 | 12:45 PM
c4cruiser's Avatar
c4cruiser
There are three wires under the center console. One wire is a ground, another is a 12v source that is controlled by the ignition switch and the last is one that is a always-hot 12v. The two 12v wires are protected by 10A fuses.
At just about every parts store I go into, there are USB plugs that go into the cig lighter or accessory ports. These usually have USB connectors (2.0 and 3.0). Some cost about a buck, others may be 3-4 bucks.
To Accessory plug
