SIR Code 26
Old Apr 10, 2017 | 03:39 PM
IHBD's Avatar
IHBD
Pro Mechanic
Default SIR Code 26
Correct me if I'm wrong, please.
In 1990, Code 26 is a frame sensor resistance problem.
In 1991, Code 26 is "open steering column circuit". (Clockspring).
Am I correct that if I used a 1991 FSM to diagnose a Code 26 on a 1990, I was working on the wrong thing? Thanks.
Old Apr 10, 2017 | 06:43 PM
Churchkey's Avatar
Churchkey
Have a 90 the SIR is a one year only system, you need a 90 FSM.
Old Apr 10, 2017 | 08:16 PM
WVZR-1's Avatar
WVZR-1
I believe that I can sort all of the '90 diagnostics for you and send via email. I've dropped you a PM with my email. With the FSM information and a couple of the TSB you should have no issues. The TSB are likely sufficient but you might as well have it all.
To SIR Code 26
