Check Engine
Old Apr 12, 2017 | 11:03 PM
tgeary's Avatar
tgeary
Cruising
Default Check Engine
My check engine light came on. Had it diagnosed and they said the EGR valve was completely seized and the o2 sensors before and after the cat converter were bad.
They fixed those and I drove for about a day and the check engine light came on again.
What could it be?
This is on my 1996 Corvette C4
Old Apr 12, 2017 | 11:26 PM
1993C4LT1's Avatar
1993C4LT1
Just because there is a code for the o2 sensors, doesn't mean they are bad. They could have been reading rich or lean for whatever reason and there could have been a "rich o2" or a "lean o2", doesn't mean they are bad. I would read the code(s) and report back here.
Old Apr 12, 2017 | 11:32 PM
tgeary's Avatar
tgeary
Cruising
Do I take it back to the dealer and have them diagnose the codes again?
Or is there another way to get the codes?
Old Apr 13, 2017 | 11:43 AM
DGXR's Avatar
DGXR
The C4 models up to 1995 have OBD1 (on-board diagnostics version 1). The 1994 and 1995 models have OBD2 connectors but were still running the OBD1 system. Confusing. The 1996 Corvette has true OBD2.
Here are a few threads for your reading:
https://www.corvetteforum.com/forums...ic-system.html
https://www.corvetteforum.com/forums...n-96-cars.html
https://www.corvetteforum.com/forums...ull-codes.html
Post #5 in the last link will show you the "paper clip" method of retrieving codes from your 1996. Be patient and write it all down before clearing.
Old Apr 13, 2017 | 11:51 AM
vader86's Avatar
vader86
Pull the code, see what it is yourself. We'll tell you what to fix.
In general, fix the code closest to the front of the car first and go backwards from there resetting each time. Usually one code spawns several others.
Old Apr 13, 2017 | 06:14 PM
GUSTO14's Avatar
GUSTO14
If you don't have a hand held scanner, or a friend that does(?), take it to your local Autozone or Advance Auto and ask them to read it for you.
Oh, and welcome to the Corvette Forum!
GUSTO
To Check Engine
