C4 wheel adapters
Old Sep 27, 2002 | 01:38 PM
Black94LT1's Avatar
Black94LT1
Cruise-In 10-11-12 Veteran
St. Jude Donor '09-'10-'11-'12-'14
Default C4 wheel adapters
I've never been pleased with the look of the 8.5 inch wheels on the front of later C4s, and since I just bought my collector edition wheels and brand new tires, I'm kind of stuck with them.
Has anyone considered or tried putting early C4 wheel adapters on the front to bring the 8.5 wheels more even with fender.
Just a thought, as I'm not even sure how thick the adapters are. It seems that a half inch would do it.
Old Sep 27, 2002 | 01:45 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: C4 wheel adapters (Black94LT1)
or you could do like I did and put 9.5 rims on the front.
Old Sep 27, 2002 | 01:49 PM
Black94LT1's Avatar
Black94LT1
Default Re: C4 wheel adapters (Mr Mojo)
I would but I've only bought the wheels a year ago, and the tires have less than 3000 mile on them, so I would potentially be stuck with those.
Plus there is the wife to deal with when it comes to buying more wheels (8 extra wheels and 4 tires in my garage now from my trucks)
Old Sep 27, 2002 | 04:46 PM
hz900's Avatar
hz900
I don't know about the adapters but any specialty wheel outlet/shop should be able to sell you a spacer any width you want for probably alot cheaper than you can buy the C4 adapters, unless you find them used. Just a thought.
Old Sep 27, 2002 | 04:59 PM
Black94LT1's Avatar
Black94LT1
Default Re: C4 wheel adapters (hz900)
I had considered that, but I was concerned that there would not be enough wheel stud left to hold the wheels on safely. My understanding of the adapters its that they bolt on to the existing studs and then have anohter set of studs to mount the wheels to. Can anyone clarify this?
Old Sep 27, 2002 | 08:29 PM
Mr Mojo's Avatar
Mr Mojo
Like this:
Old Sep 27, 2002 | 08:35 PM
Sharky Guam's Avatar
Sharky Guam
The adapters are not really reccommended for anything harsh. However, with street use, they should be okay.Most adapters though are made to adapt for one bolt pattern to another.
:cheers:
Old Sep 27, 2002 | 11:25 PM
hz900's Avatar
hz900
You can buy longer and stronger studs if that is the case, although like Sharky said I would not recommend them for anything hardcore.
Old Sep 27, 2002 | 11:32 PM
baddmann's Avatar
baddmann
Mine car came with the 8.5s up front, and when I bought the A-molds, I went 9.5 all the way around... I have never liked the 8.5s on the front, looks a little wimpy to me.
Old Oct 2, 2002 | 08:34 AM
Black94LT1's Avatar
Black94LT1
Like this:
Does anyone know how thick these adapters are?
Never mind, I checked Summit, and they are listed as 1" thick, which is too much.
[Modified by Black94LT1, 6:39 AM 10/2/2002]
Old Oct 2, 2002 | 09:13 AM
vettmech's Avatar
vettmech
I would vote for the longer studs and spacers........ I used some adapters on a hot rod truck once and when I finally bought some wheels that bolted right on we couldn't get the adapters off because the studs had BENT. We had to cut them with a torch. Also if I remember right they don't allow adapters at the drag strip..........must be something there........... :seeya
To C4 wheel adapters
