1985 Code 33
Old May 1, 2017 | 09:56 PM
85vegasvette's Avatar
85vegasvette
Default 1985 Code 33
Okay i am offically scratching my head, 1985 here, replaced the connector for the MAF, Just got a factory MAF, still throwing a code, it idles fine when cold, the when i accelerate it bogs and backfies , when it gets warm its fine, it did the sdame thing with my other MAF , also tried the 88 MAF switch that was horrible, Which i stil have if anybody needs, but i am offically stumped, found a couple bad vacum lines replaced....so now i am at my wits end...HELP
Old May 1, 2017 | 11:15 PM
Tod Stiles's Avatar
Tod Stiles
Code 33 is MAF high (voltage) i.e., showing more air flowing then there is. Here are the trouble shooting charts. I'm not too keen on the last part of test three where you probe the MAF harness with a 12v light. I'd try to avoid that if possible.
I'm going to assume you have no other codes set and that you've cleared the ECM, restarted and have code 33 again. I'd check you're grounds and look over all your wiring for breaks or shorts before you go too far with this.
Old May 2, 2017 | 02:50 AM
Cliff Harris's Avatar
Cliff Harris
Code 33 is an open connection from the MAF to the ECM, most likely a broken wire or corroded connector pin. Basically, the voltage is going to 5 volts because of the pullup resistor inside the ECM.
Old May 3, 2017 | 12:15 PM
junkyard_dog72's Avatar
junkyard_dog72
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
2016 C4 of the Year Finalist
Tuning in, I have this same exact issue
Old May 3, 2017 | 09:41 PM
85vegasvette
o
Gonna look at the connector again maybe re solder the wires, ..but I'll folks then and see, all this from.changing an air filter. ..amazing
Old May 13, 2017 | 08:56 AM
85vegasvette
o
Old May 14, 2017 | 07:06 PM
gerardvg's Avatar
gerardvg
Hi here is the wiring diagram for the MAF to burn of module and ECM connections.
To 1985 Code 33
