Need Brakes, any recommendations
Old 06-24-2017, 10:21 PM
89dd
Support Corvetteforum!
89dd's Avatar
Default Need Brakes, any recommendations
My stock 89' coupe needs brakes. Car is used mostly as a weekend cruiser. Was looking at Powerstop k1518 drilled and slotted rotors and ceramic pads kit. Anyone use these, or have any other recommendations.
Thanks in advance.
Old 06-25-2017, 09:40 AM
charliet615
charliet615's Avatar
I just installed the Summit Power Stop drilled and slotted rotors, front and rear, and ceramic pads, so far so good. Great shipping also. 93 LT1
Old 06-25-2017, 09:53 AM
Joe C
Joe C's Avatar
I just bought a set of powerstop "slotted only" rotors and evolution, carbon-ceramic, pads for my 85. it's pretty much a DD, and stock brakes are more than adequate for my needs. I use to have drilled and slotted, but noticed that I developed small hair-line cracks around the drilled holes. bought the rotors from rockauto, and the pads from summit. waiting on cooler weather for installation -
Old 06-25-2017, 09:56 AM
QCVette
QCVette's Avatar
In the C5 section there are a lot of threads about PowerStop ceramic pads with their drilled and slotted rotors. The opinions are very positive. There hundreds (maybe even a thousand) comments that like these. Good performance and the zinc plated rotors hold up well and resist rusting.
The one exception is that if you are tracking the car there have been some rotors cracking because of the drilled holes. However for street and limited track use they seem to be holding up fine.
I bought a set, but haven't put them on yet.
Old 06-25-2017, 10:00 AM
Cjunkie
Cjunkie's Avatar
Total overkill on an almost 30 year old car thats a weekend cruiser......UNLESS you are tracking the car every weekend.
Go to AutoZone more than sufficient. I have less than $200 in 4 new rotors and front and rear pads total on my 86 and it stops just fine like an 86 Corvette should.
Old 06-25-2017, 10:08 AM
mark970
mark970's Avatar
i just buy my stuff from NAPA. I'm just a regular driver...not interested in performance or track related driving...plain old regular components are all i need. with that said i have no idea how much fancy rotors cost but its $200 or more for a brand name pad like Hawks when i can get ceramic pads from NAPA for $60
just my 2 cents
Old 06-25-2017, 10:24 AM
Joe C
Joe C's Avatar
Originally Posted by mark970
i just buy my stuff from NAPA. I'm just a regular driver...not interested in performance or track related driving...plain old regular components are all i need. with that said i have no idea how much fancy rotors cost but its $200 or more for a brand name pad like Hawks when i can get ceramic pads from NAPA for $60. just my 2 cents
, plain old components are fine for a DD. FYI, my powerstop (slotted) rotors ran about $55 each - pads, as I recall, around $60-70 - total, front and rear. not sure of how much of an upgrade these components are - I just went this route. it was kind of a toss-up - almost went with wagner OE replacement stuff.
Old 06-25-2017, 10:40 AM
Cjunkie
Cjunkie's Avatar
I spent $20 for my pads
Old 06-25-2017, 10:41 AM
QCVette
QCVette's Avatar
I looked at the PowerStop setup partially because they were priced so well.
I bought the C5 set for $175 for all four zinc plated drilled and slotted rotors with new Powerstop Z16 pads on all wheels.
I thought that was a great price and was less than I found at the local parts stores.
You need to evaluate what features you want and compare to prices to make your decision.
Good luck.
mark970 (06-25-2017)
Old 06-25-2017, 03:09 PM
mark970
mark970's Avatar
Originally Posted by Joe C
, plain old components are find for a DD. FYI, my powerstop (slotted) rotors ran about $55 each - pads, as I recall, around $60-70 - total, front and rear. not sure of how much of an upgrade these components are - I just went this route. it was kind of a toss-up - almost went with wagner OE replacement stuff.
almost seems like "upgraded" rotors are cheaper than plain old rotors...in that case "less is more"...i will investigate for my next brake job.
thanks for the great input
Old 06-25-2017, 03:24 PM
johno504
johno504's Avatar
St. Jude Donor '19
NAPA sells both china and NOT china rotors. big difference in cost.
Old 06-25-2017, 05:19 PM
89dd
89dd's Avatar
That's what I was thinking. But is there any noticeable difference over OEM, or is it just for show.
Old 06-25-2017, 06:02 PM
c4cruiser
c4cruiser's Avatar
No real need for drilled and slotted rotors on a car that is just a weekend ride. Stock rotors will do just fine. And with OEM wheels, you won't really see the rotors. Look at AC Delco "Professional Grade" rotors or Raybestos "Advanced Technology rotors. Centric rotor are good too.
Ceramic pads will work fine! Very little or no dust and for cruising, they will provide plenty of stopping power. Hawk has a ceramic pad set as does CarboTech. Also consider the Hawk HPS pad. These are a semi-metallic compound but they don't give off very much dust and will work for some "spirited" braking.
I would also suggest a complete brake fluid flush and refill. A good DOT3 fluid like Valvoline SynPower, Castrol LMA, or even the Ford HD Motorsports fluid will work fine for street use.
Old 06-25-2017, 07:54 PM
Cjunkie
Cjunkie's Avatar
I paid $36 and $40 each for my rotors.
Old 06-25-2017, 08:22 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Nice.
How'd those dog-bone & sway-bar bushings look?
Any deep cracking on the brake lines?
Check the U-Joints for rust under the dust caps?
Old 06-26-2017, 12:11 PM
Paul Workman
Paul Workman's Avatar
Thanks in advance.
There's (generally) two types of drilled (iron) rotors: Those WITH cracks and those that WILL have cracks!
So the question is NEED vs. LOOKS.
Need:
Fact: Once the tires lock up, no more expensive or exotic brake upgrade (pads/rotors, etc.) is going to stop any better. Tires come into play - hand in hand with brake upgrades.
Rule of thumb: Threshold limits: Only YOU can determine if your ability to stop/slow is adequate for your most aggressive demands:
If you find yourself standing on the pedal and still have traction, but not slowing fast enough, you need a better brake (rotor, pad, caliper) "system"
If you find you're anti-lock system is activating its your tires failing to grip. Tires may be in order.
Beyond NEED is WANT. The sky is the limit, far as that and your wallet goes. But, I would caution against drilled rotors. Slotted is OK, but only $pecial alloy rotor$ will avoid cracking and ultimately having to replace them - before they start throwing chunks!
Old 06-26-2017, 05:58 PM
81c3
81c3's Avatar
I've had drilled rotors on a few of my Vettes.... No tracking the car... regular pleasure driving and normal use,. Never had any cracks. My Mercedes comes factory with them, no cracks.
Competition or Track days is different... You will crack around the holes. I've seen guys post up pics of the carnage. Its definitely an aesthetic thing more than anything else...
Old 06-26-2017, 06:51 PM
89dd
89dd's Avatar
Thanks for all the responses guys.
Decided to go with solid rotors and ceramic pads.
Ordering parts, and install over the weekend.
Will keep you posted.
Old 06-27-2017, 02:09 PM
mark970
mark970's Avatar
that's exactly what i did. I bought my stuff from Napa...but i do need to investigate some of these "upgraded" rotors that are cheaper than Napa's. My car has the 13" fronts (J55) and surprisingly they were under $70 each...
thanks for the thread, its been usefull!!!
To Need Brakes, any recommendations
Quick Reply: Need Brakes, any recommendations
