Targa Trick
Old Jul 5, 2017 | 01:11 AM
AstroMan1's Avatar
AstroMan1
Default Targa Trick
I was detailing my 84 recently and I did my weatherstripping with di electric grease. When I got done I decided to leave the top loose! I'm just leaving it loose when I'm not driving. Just takes a minute to hit the road!
Old Jul 5, 2017 | 01:43 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Be careful not to forget that it is not tightened down. Many C4 users have joined the Flying Roof club just for that reason.
Old Jul 5, 2017 | 06:14 AM
Eljay's Avatar
Eljay
I had mine off last weekend and it is nice but I wish it was easier to take off and put on. I have had three "T" roof vehicles ( 91 Firebird, 81 Vette, 01 Camaro) and all of those were much easier to take off.
Old Jul 5, 2017 | 06:56 AM
Joe C's Avatar
Joe C
personally, I wouldn't trust myself to remember to tighten down the roof hardware. with my luck i'd get a free membership into that flying roof club -
BTW, for lubing the weather stripping, I use silicone spray in an aerosol can. I spray an amount into s small plastic container, and use a 1" foam bush and "paint" a coating - let it soak in for a minute or so, and wipe off the excess. I usually do it a couple times a year. seems to work better than straight grease -
Old Jul 5, 2017 | 09:17 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Like others have said, don't let it get you into the flying roof club.
My '96 roof is all scratched up from flying (by the previous owner). Somewhat lucky though. A lot of scratches, but not cracked or broken.
Old Jul 5, 2017 | 09:23 AM
Raidmagic's Avatar
Raidmagic
I usually leave the roof off the car and if I leave it I just set it on and put the drivers side front bolt in snug and the pass. side rear finger tight. Easier to remove when I leave and keeps the water out if it rains.
Old Jul 5, 2017 | 02:16 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
What is your reasoning for doing this?
Old Jul 5, 2017 | 04:57 PM
nutsy's Avatar
nutsy
I had mine of for the 1st time this weekend and loved it. I'm with you, I had a 72 coupe and it took about 5 seconds to take off per side and no help. wish they had the same setup as my 72. also I read about all kinds of creeking noises and handling problems with it off but I went on a 60 mile ride with no problems except when I hit a bump the top bumped the back window sometimes.
Old Jul 5, 2017 | 08:48 PM
Benny42's Avatar
Benny42
I have found 2 C4 tops on the side of the road. 2 of them! Don't leave it loose or i may find yours. (both were ruined but had good hardware) I drive a lot in my profession.
Old Jul 5, 2017 | 09:01 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
how is this a Targa Trick?
Old Jul 5, 2017 | 10:03 PM
xrav22's Avatar
xrav22
You should have a latch to hol the top at 3 points. Should not move
Old Jul 5, 2017 | 11:43 PM
AstroMan1's Avatar
AstroMan1
It's "just sitting" on the car only while I'm not driving. It's so much quicker to take off. That's the trick. I did have rain today so it's tight again. I always have something to remind me to do a checklist. Not just the car!
Old Jul 7, 2017 | 11:17 AM
TorchTarga94's Avatar
TorchTarga94
Cool Trick! Wish I would have thought of that...
Old Jul 7, 2017 | 01:12 PM
James84vette's Avatar
James84vette
The only time I have mine on is when it's parked at work. In the garage, I never put the top on.
Old Jul 7, 2017 | 03:51 PM
nutsy's Avatar
nutsy
yep, I put the holder in the hole but it still seemed to bump window unless I didn't have it in correctly, do you have to push it far into the front 2 holders? I didn't force it in to them
Old Jul 8, 2017 | 07:09 AM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
flyingroofclubmember> Still waiting for the "why" would you do this? What is the trick Einstein ? <flyingroofclubmember
Old Jul 8, 2017 | 08:52 AM
81c3's Avatar
81c3
Thats funny.... I never take mine off...
To Targa Trick
Old Jul 8, 2017 | 09:07 AM
belairbrian's Avatar
belairbrian
I guess I just don't see the point. it takes less than 5 minutes to remove or install the top. Are T-tops faster, Yes. But it's not like it's an hour long job.
Old Jul 8, 2017 | 09:36 AM
RIC96's Avatar
RIC96
Wish I lived nearby. I'm always looking for drone video opportunities!
Old Jul 8, 2017 | 09:52 AM
Cruisinfanatic
closer to 1 if you have a driver and bit
