Open Lid
Old Oct 2, 2002 | 01:35 AM
Red Tornado's Avatar
Red Tornado
Default Open Lid
Ok I'm gonna suck it up, shrink 12 inches & ask the most retarded question in the history of the CF. I've noticed many members have cut their lids as a mod to allow for freer air flow. Here's the question: doesn't this cause extra dirt to get in around the air filter? I wonder how godd this is for daily driving. Ok now I'm ready for the onslaught! :jester
Old Oct 2, 2002 | 01:36 AM
vader86's Avatar
vader86
Default Re: Open Lid (bradvette)
the K&N takes up all the open area, you just may want to put some tape around the airbox if youre actually worried about that
But i didnt, the K&N took up all the area.
Old Oct 2, 2002 | 03:12 AM
RadPolo96's Avatar
RadPolo96
My K&N is still clean :cheers:
Old Oct 2, 2002 | 07:03 AM
STREETKNIGHT's Avatar
STREETKNIGHT
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Open Lid (RadPolo96)
Mine also :D Go ahead and cut it :yesnod:
Don't know how much "real" performance it gives you, but it feels better and sounds :cool:
:seeya :flag
Old Oct 2, 2002 | 08:03 AM
Eric 96's Avatar
Eric 96
The Filter is still filtering the same air....just more of it! The way the factory lid is made wouldn't filter out any dirt.
Old Oct 2, 2002 | 08:58 AM
vettmech's Avatar
vettmech
Default Re: Open Lid (Eric 96)
Mines cut and I drive it every day ........no problems ever .......cut it :seeya
Old Oct 2, 2002 | 09:42 AM
DarkHalo's Avatar
DarkHalo
From: SCMR Rat Pack'r Charter Member, Inland Empire Chapter
Default Re: Open Lid (vettmech)
Will that affect smog inspections though? theyre REALLY tight about stuff like that out here in Cali...anyone have any info on that?
Old Oct 2, 2002 | 10:52 AM
STREETKNIGHT
Default Re: Open Lid (DarkHalo)
X-actly why I don't live in California :lol: :lol: ...Just had to throw that in...they just dumped emission testing in Florida a few years back. :seeya
Old Oct 2, 2002 | 11:34 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
I doubt it since it's not an emission item.
Old Oct 2, 2002 | 11:51 AM
91TurqC4's Avatar
91TurqC4
You may want to look at this archived link before you do anything.
http://forums.corvetteforum.com/zerothread?id=92469
:seeya
Old Oct 2, 2002 | 12:02 PM
cire96's Avatar
cire96
Bradvette:
Remember the only realy dumb question is the one unasked. The stock C4 GM lid was designed to satisfy an internal GM standard that requires any of the General's cars to be able to drive unafected through (I think) 6" of standing water while the front end is hosed down with a monsoon level rain.
These are not exactly the conditions that most of us drive in. The K&N Cut Lid (or a home made unit) really doesn't have any affect on the driving rain problem. It could however cause problem with the GM standing water standard however. BTW, the car does run ever so slightly stronger with the K&N cut lid due to less restriction.
Cire96
P.S. You now know much more than you ever wanted to know about this topic. :cheers:
Old Oct 2, 2002 | 12:32 PM
Red Tornado
Default Re: Open Lid (cire96)
Thanks everybody for your input :seeya You guys and also everybody here are simply the best :flag :chevy
Old Oct 2, 2002 | 12:33 PM
War Machine
Default Re: Open Lid (91TurqC4)
:seeya
In response to What MrMojo said:
Some have used K&N and K&N claims HP gains, but do they really? Nobody can truly answer that unless they have tested at a track under the same exact conditions.
I kept track of the hwy fuel mileage on my van all summer long, w/ and w/o the air on and the comparison I made with the K&N was w/o the air conditioning on. I was able to get 13 mpg hwy w/ a paper filter. I installed the K&N and under similar testing conditions I gained NADA! I still get 13 mpg! If the K&N gives you nothing then the cut lid will just make it sound :cool: that's about it. I bought the Vette with a K&N already installed so no testing done there.
Old Oct 2, 2002 | 12:57 PM
BrianandDenise's Avatar
BrianandDenise
Yeah. I want to know if anyone is getting more mpg's with the K&n and the cut?? Us automatic people get terrible mileage. I would ask for a pic of the cut lid but I am sure i will see enough a the NCM in June.
Old Oct 2, 2002 | 02:29 PM
vettmech's Avatar
vettmech
Default Re: Open Lid (BrianandDenise)
You may NOT see many cut lids at the NCM..........I have mine cut and it's not visible. I can FEEL it but I better not see anyone getting in there close enough to be able to tell............. know what I mean? :seeya
Old Oct 2, 2002 | 03:24 PM
guywade's Avatar
guywade
no sweat , cut the lid, dirt catcher is what a filter does, just clean when you have to! :D
Old Oct 2, 2002 | 06:56 PM
n1kki6's Avatar
n1kki6
I did it and my k& N is clean as can be
To Open Lid
Old Oct 2, 2002 | 07:52 PM
GDP's Avatar
GDP
I cut the lid the other day. THOUGH I left it stock looking. Removed pop rivets, cut the plastic underneath larger and cut a big rectangle in the metal piece. Then put some pop rivets back on, looks very stock. Did it increase performance? I doubt it. Can now say I've cut the lid? :yesnod:
PS, I've HEARD that the cut lid only really makes a difference at higher speeds. Port and polish your MAF if you want less restricted air. It's the stealthiest mod you can do, and it feels stronger afterward. Remember, every little bit helps. Maybe the cut lid will give you 2 HP, 1ft/lb BUT if you think about it, any number can be divided by two. You can port and polish your heads, let's say that gives you 50 HP. Well 25 free mods with 2 HP gains will equal that. 2 HP is 2 HP, and as always, more is better. Marginal increases are still increases. Just some food for thought.
[Modified by GDP, 5:53 PM 10/2/2002]
Old Oct 2, 2002 | 08:32 PM
Zidane's Avatar
Zidane
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Could someone please tell me some detailed instructions on how to do this? I would really apreciate it! I think that i could do it if it doesnt require any real sophisticated tools.
Old Oct 2, 2002 | 08:36 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
No extra dirt gets in around mine...its a tight fit on mine...although I didn't cut mine...I just bought another one already done and if I want to go back to stock I dont have to buy a new one...cause I now have the old one...go figure!...pay now save later... :D :cheers:
