C4 Dash Rivets
Old Jul 16, 2017 | 08:01 AM
sporanox's Avatar
sporanox
Default C4 Dash Rivets
I had to remove the rivets in the dash understructure to get my heater core back in. Can the rivets be replaced with standard rivets or are those special?
Old Jul 16, 2017 | 08:31 AM
yd328's Avatar
yd328
Any pics of the rivets? McMaster Carr has a big selection of different types of rivets.
Gary
Old Jul 16, 2017 | 12:40 PM
sporanox's Avatar
sporanox
Default Rivets
Gary
I drilled them out already. I was wondering if anyone had replaced this with screws or standard size rivets. I have a 91(non-bread basket) dash and the rivets are on the left side of the passenger area.
Old Jul 17, 2017 | 12:00 AM
mark970's Avatar
mark970
I cant imagine it matters at this point. I would suggest SST rivets because it is a dash and provides structural safety in an impact but on the other hand if you thought you may ever need to get back in there aluminum rivets would be MUCH easier to drill out. just get the right size rivet
Old Jul 17, 2017 | 06:36 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
When I did the heater core in my '85 years ago, I didn't have to drill out anything. Removed the passenger seat, which gave me room to lie on my back and remove the 7mm screws holding the box together that housed the heater core. One brace was in the way, which unbolted easy. Didn't have to mess with any rivets. What year is your car?
Old Jul 17, 2017 | 10:01 AM
confab's Avatar
confab
Does it matter? If it were me, I would use rivets of the same material I drilled out. (I'd guess aluminum.)
You can size them with a drill bit.
PS: IHBD is right, the big pop rivets ones take a giant tool to use, but it's usually pretty cheap.. If you can't borrow a riveter, even the ginormous one is 20 bucks at Harbor Freight.
https://www.harborfreight.com/heavy-...tle-66422.html
Good Luck!
Old Jul 17, 2017 | 10:16 AM
WVZR-1's Avatar
WVZR-1
In '90+ cars I believe there's rivets that hold the actual plastic case components together. If these are what the OP is referring to I'd think aluminum for sure.
If it would aid assembly and they were very accessible I might be tempted to use an appropriate sized "push plastic" rivet. There's some maybe very desirable reasons to use them.
**** I recalled from some time ago seeing these mentioned. If this link works you should land at the pieces I recall. If the link doesn't stick go to post#135
https://www.corvetteforum.com/forums...post1585219751
Old Jul 17, 2017 | 10:20 AM
mark970's Avatar
mark970
my only input about actually using a rivet gun would be to make sure if you go out and buy a giant rivet gun that you have room to use the giant rivet gun...those things are in fact giant. you can use them on doors with no problem, but depending on the dash location, it may not fit and you're out some money.
like Confab said, use a drill to put in the hole to size the rivet...i always like to use aluminum because it drills out much easier should you ever need to get back in an area.
i think at this point it comes down to the location of the rivet and what purpose does this rivet provide (safety, structural or is it non-functional and simply just keeping something from rattling).
myself...i tend to do things proper (especially if it's something so simple as a rivet) so if a metal rivet came out i would put a metal rivet back in. if you cant recall the rivets material, scratch it to see if its steel or aluminum (but it seems most rivets were aluminum)
i guess as long as you dont use duct tape, you'll be fine
To C4 Dash Rivets
