Diff fluid change question
Old Aug 3, 2017 | 09:15 AM
sb66's Avatar
sb66
Default Diff fluid change question
hey everyone
I was getting ready to change the rear fluid and I wanted to double check - for this the car should be driven a little first to get everything stirred up to get pumped out?
and does the whole car need to be lifted? if so - just high enough for you to get under?
again just wanted to double check everything before getting started -
any help would be great
thanks
Sean
Old Aug 3, 2017 | 09:30 AM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Should be an easy project, drive it to warm it up and be safe and use jack stands.
Old Aug 3, 2017 | 09:33 AM
Paul Workman's Avatar
Paul Workman
Instal a drain plug. Easy pleasy!
Old Aug 3, 2017 | 09:35 AM
The Green Hornet
Don't forget the limited slip additive.
Old Aug 3, 2017 | 09:48 AM
sb66's Avatar
sb66
thanks everyone - !!
Old Aug 3, 2017 | 09:49 AM
sb66's Avatar
sb66
almost forgot - any thread seal on fill plug? or just clean and re-install?
Old Aug 3, 2017 | 10:44 AM
c4cruiser's Avatar
c4cruiser
No real need for a sealant on the fill plug. Clean the threads and use a small amount of anti-seize on the plug threads. Don't over-tighten the plug!!
There is no factory drain plug on the C4 diff case. Some of the Corvette catalogs have self-tapping plugs but you would have to drill a hole and then thread in the plug. Once that is done, you could use a small amount of anti-seize on the plug threads.
Given that there is no specific requirement for changing the gear oil, getting a $5 hand pump from Harbor Freight would be a better deal.
Old Aug 3, 2017 | 11:26 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
No, fill plug doesn't need anything, just clean and tighten.
Old Aug 3, 2017 | 01:16 PM
sb66's Avatar
sb66
thanks everyone - definitely used the harbor freight pump - probably over tightened the plug - I did not tighten it to the point it would not move - there is still a few turns left - but I feel like I may have snugged it a bit extra -after I realized that I did not want to loosen it - too tight in there for any kind of torque wrench that I have - I think it asks for 10 or 12 ft/lbs?
anti seize would have been smart - I did not think of that
hopefully it will be ok?
thanks
Sean
Old Aug 3, 2017 | 01:17 PM
sb66's Avatar
sb66
I have some of the copper anti-seize paste will that work?
Old Aug 3, 2017 | 01:25 PM
WW7's Avatar
WW7
Yes it will , But I didn't use anything on mine and after 10 years it came right out.....WW
Old Aug 3, 2017 | 01:28 PM
sb66's Avatar
sb66
thanks - I am hoping it will be fine as well
Sean
Old Aug 3, 2017 | 07:03 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
no need
To Diff fluid change question
