LT-4 Opti
Old Aug 6, 2017 | 09:57 PM
glefebv's Avatar
glefebv
7th Gear
Default LT-4 Opti
Hi all, I have a 96 with the LT-4 engine. I have recently completed installing a new opti, I do have one problem though. Right behind where the #1 plug wire connects to the opti there is a small diameter pipe stub, I have placed the 1/4 hose to this pipe stub, but cant figure out where the other end of the hose is supposed to go. Any suggestions or guidance will be much welcomed and appreciated.
thanks to all & God bless,
Gary L.
Old Aug 6, 2017 | 10:01 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Where did you remove the other end of the hose from??
That's where it's supposed to go.......
Old Aug 6, 2017 | 10:06 PM
glefebv's Avatar
glefebv
7th Gear
Yes, I realize that, however it was two months ago that I started this task and now I cant remember/figure out where the one end goes, any suggestions?
Old Aug 6, 2017 | 10:07 PM
rocco16's Avatar
rocco16
Actually, it appears to plug in to the top of the rubber boot between the mass airflow sensor and the throttle body.
Now, I have a question for you: what type/size of fasteners are used to fasten the bottom of the kick panel directly under the steering column?
There are three on the bottom and two on the top. All three bottom ones on mine are missing and I want to use the correct replacements.
Thanks.
Old Aug 7, 2017 | 12:36 PM
mtwoolford's Avatar
mtwoolford
Thanks.
Dunno bout the "correct" stuff, but any full size GM car of the era in a wrecking yard ...excuse me... "salvage" yard should yield you a pocket full...
with that said, the oem fasteners were typical GM cheapo's; thin stamped sheet metal and sheet metal screws...yeah they went together fast on the assembly line, but gradually, as I go through my interior I replace the oem stuff with similar but much better quality stuff designed to use machine screws...available at any well stocked hardware store.
To LT-4 Opti
