Won't Idle
Old Aug 9, 2017 | 11:48 AM
BillDurant's Avatar
BillDurant
Default Won't Idle
Hi all I have a 1989 C4 Convertible Just bought 2 months ago
I feel got a good deal and knew going in there would be issues
Actualy the car has been running fine until 4 days ago. It started to idle high. Would stop at a light and if I pushed down on the gas peddle it would go back to normal idle. But now car starts runs but let go of the gas peddle and it shuts down Won't Idle at all. I'm no mechanic but been reading few things on here. Should I go and buy and install a new Throttle Position sensor and if I do is it just plug and play or would the new need adjustments?
Or what about the Idle Air Control Valve right under the TPS
Or just take it to a mechanic ?
Old Aug 9, 2017 | 10:03 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes, I'd check that. The IAC may be out of adjustment.
Old Aug 9, 2017 | 11:49 PM
aklim's Avatar
aklim
How would it suddenly fall out of adjustment unless it is faulty?
To Won't Idle
