Need help mentally.
Old Aug 30, 2017 | 10:07 AM
rappini's Avatar
rappini
Default Need help mentally.
Changed out my headlight actuator gear on my 92, while assembling the headlight back to the hood I dropped a 10mm nut in the front of the car and it disappeared and yes I've been looking for it all day, its gone. Does anyone know where I can get it's replacement. I found a dealer that has the 10mm but its different than the original which means I have to paint it black and the spin washer is smaller than the original.
As usual any help would be appreciated.
Old Aug 30, 2017 | 10:39 AM
Ranger72's Avatar
Ranger72
I dropped a nut in the same area. I was able to find it after 10 mins of fishing with a bendable pole magnet.
Old Aug 30, 2017 | 10:40 AM
ovrebo1's Avatar
ovrebo1
Go to ACE, pay 20 cents for the nut, call it a day. No one will ever see it and see that its not factory and even if someone did, they wouldn't care.
OR, go to a you pull it yard and I'm sure GM used the same nut on ALL their cars from that era.
Old Aug 30, 2017 | 11:02 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Old Aug 30, 2017 | 11:40 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Getting mental over a nut....... thats just
Old Aug 30, 2017 | 11:48 AM
haxxx's Avatar
haxxx
I had dropped one of the clips for the wire looms when I was changing spark plug wires about a month ago. Drove me nuts. I just finally found it last week when i was cleaning.
Old Aug 30, 2017 | 12:15 PM
sluggballz's Avatar
sluggballz
You missed the opportunity!!
Getting mental over a nut....... that's just nuts!!!
Old Aug 30, 2017 | 03:27 PM
pezter22's Avatar
pezter22
I taped a magnet to a long piece of wire and fished around. I found several nuts I guess lost by previous owners.
If you want the OEM part, you can also find them on ebay.
Old Aug 30, 2017 | 04:32 PM
81c3's Avatar
81c3
[QUOTE=JrRifleCoach;1595470507]
Thats what she said....
Old Aug 31, 2017 | 02:40 PM
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
[QUOTE=81c3;1595472705]
Old Sep 2, 2017 | 02:59 AM
scrappy76's Avatar
scrappy76
so you lost a nut, aren't you being a little premature to think your crazy ?
Old Sep 2, 2017 | 08:05 AM
jetskibruce's Avatar
jetskibruce
I don't really think I have worked on the car unless I have dropped a nut, bolt, or screw into some crevice. I have been lucky to find most, I just don't want a screw left where a tire can find it.
Old Sep 2, 2017 | 09:26 AM
lt4obsesses's Avatar
lt4obsesses
I lost a 10mm socket in the engine bay once. Looked everywhere, couldn't find it.
My solution was to just to quick start off, and sure enough, it slid right out and was on the ground where the car was. If you can't pull it out, shake it out. lol (yeah, I know..."that's what she said"...)
To Need help mentally.
