Sound Deadening!
Sound Deadening!
So I spent a little time today sound deadening the storage compartments on the Vette, took some patience working in such a tight spot. I only hit my head on the roof roughly 15 times ! I basically used the carpet insert to outline on the sound deadening and it came out pretty decent. I couldn't get every single little crack but if I spent a few hours doing it i'm sure it could be better, but seeing as it's something noone will see I think it's just fine. I noticed that the drone in 6th gear while cruising is actually a little bit quieter, which is nice
- as for sound deadening - every little bit helps!
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
It makes a big difference
I already did the cabin, outside skirts, and the driver's door panels. I have to do the passenger side to finish.
I also added good quality heat barrier to the transmission tunnel, below the shifter, and to the resonator. All made a big difference, the center console is no longer transmitting heat and my legs are no longer well done.
PLRX (09-04-2017)
2017 C4 of Year
I didn't take photos of it. That day was 115°F but will take photos when I get the other side done.
xrav22 (09-04-2017)
