Sticky Console
Old Sep 17, 2017 | 10:15 AM
SteveBlakeman's Avatar
SteveBlakeman
Default Sticky Console
It appear that it's been a few years since anyone has addressed this issue, so I'll tell my story here.
The problem was that my shift plate console was extremely sticky and no matter what cleaner I applied, it made no improvement. So to this forum I went...to see what others have done to fix the problem.
I learned that the Dulso coating (a thin rubbery substance applied over the plastic by the factory) does deteriorate in some situations, causing the stickiness. My 95 C4 has been a garage queen all of it's life so the cause of the stickiness clearly was not due to intense heat. I'm not sure why it happens.
I did a search of the forum to learn how to fix the issue and found several ideas and solutions. I chose to go with what I thought was the "safest" chemical to apply.
I removed the console plate form the car and then removed the small door (over the cup holders). Doing all this on my work bench, I applied the Non-acetone Nail Polish Remover with a rag (purchased from Wal-Mart for less than $2). It required a lot of rubbing and scraping with my thumb nail, but after a couple hours it was down to the original plastic. This was a messy job in that as the Dulso comes off in small pieces it is very sticky.
I then sanded the console and door with dry 600 grit sand paper and thoroughly washed it before applying the Dupli-color flat black paint and clear coat as seen in the pictures.
I reinstalled everything and it looks fantastic. The paint is a perfect match to the adjacent dash, etc.
Old Sep 17, 2017 | 10:51 AM
SJW's Avatar
SJW
Wow. That came out looking beautiful! A great job well done. Congrats on the effort and the result. Thanks for sharing the how-to advice.
Live well,
SJW
Old Jul 18, 2018 | 06:10 PM
CVG323's Avatar
CVG323
tagging for later
To Sticky Console
