Headlight motor reassembly
This might have some info as well.
https://www.youtube.com/watch?v=sPj1kJm4AnU
thanks anyway.
All it says is to "check mechanical connections for binding, breakage, etc." Well, no schit Sherlock. What a helpful book. Especially if you need to swat a fly.
There are three troubleshooting charts. Basically, you're on your own to figure out what it should look like.
Studying the layout of the passenger side is no help. Some kind of subtle bend somewhere is causing the driver's side to bind.
I've had it apart, replaced ridiculously expensive bushings, measured, compared to others, etc. It still tries to tear the motor off it's mount fighting itself. Spent two frustrating hours on it yesterday.
Mine are now manual. Problem solved.
