1995 pke
Old Oct 8, 2017 | 11:02 AM
gstatucki's Avatar
gstatucki
Default 1995 pke
I am having a problem programing the PKE transmitter. Transmitter unlocks hatch but not doors or automatically opening and lock, When pushing door button it will click but not operate. Is thereanother part to system not working. Thanks
Old Oct 8, 2017 | 07:14 PM
markKlein's Avatar
markKlein
The system is turned off. Read the owners manual about this, but it can be turned off so it doesn't lock\unlock constantly when gassing up etc. To turn it on stand next to door (closed, with key out) and hold the door key down for a while, 5 or 10 seconds. You should hear a clackclack sound and now it is on. Read manual to make sure you understand how it works.
Old Oct 8, 2017 | 07:17 PM
markKlein's Avatar
markKlein
The click you hear when pushing the door button for a second is it unlocking the passenger door but not the drivers door. It does that. I'll explain later when I have a real keyboard.
Old Oct 8, 2017 | 08:15 PM
gstatucki's Avatar
gstatucki
Thanks - I got it to work - Had to hold door button for 2 sec until transmitter recycled and now ok. Not sure why transmitter losses program but now will try to remember all the steps,
Old Oct 9, 2017 | 10:42 AM
markKlein's Avatar
markKlein
The transmitter didn't "lose program", it was turned off, as I said. Now it's turned on.
Old Oct 9, 2017 | 11:33 AM
gstatucki's Avatar
gstatucki
OK Thanks very much
Old Oct 9, 2017 | 01:55 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The "door" button is not used to lock/unlock the doors.
It can be programmed to unlock the passenger door, but it will never lock either door.
That isn't how this system works.
PKE = Passive Keyless Entry
The doors will lock/unlock as needed when you approach/leave the car.
To 1995 pke
