85 code 33 question
Old Nov 4, 2017 | 04:32 PM
85vegasvette's Avatar
85vegasvette
Default 85 code 33 question
could a air Cleaner Temperature Sensor throw a 33 code, replced the pigtail and the MAF..still 33 code, it backfires when cold but when it warms up its good
Old Nov 4, 2017 | 05:13 PM
Kevova's Avatar
Kevova
Check the 2 MAF relays
Old Nov 4, 2017 | 06:07 PM
85vegasvette
85 only has the one behind the bread box.... i guess im on the hunt
Old Nov 7, 2017 | 02:32 AM
Cliff Harris's Avatar
Cliff Harris
The '85 has a "Burnofff Module" that does the same functions as the later 2-relay system.
The error code 33 is a MAF signal problem. Could be a bad connection (like a corroded connector pin) or broken wire between the MAF and the ECM. Try disconnecting the MAF and see how it runs.
To 85 code 33 question
