Engine code readers
Old Nov 11, 2017 | 03:07 PM
Eddy Gee's Avatar
Eddy Gee
1st Gear
Default Engine code readers
Hey, I'm shopping for a good quality engine code reader/diagnostic tool for my '89 C4 L98. Any ideas or suggestions? Thanks in advance!
Old Nov 11, 2017 | 03:30 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
If you just want to read the code numbers, you can jumper the A-G pins on the ALDL plug. Then just look up the code description.
Old Nov 11, 2017 | 10:00 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I used the paper clip method of jumping the ALDL too.
Take a look at
http://www.corvettebuyers.com/c4vettes/codes.htm
good luck.
Old Nov 11, 2017 | 11:04 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Better check carefully, I'd expect on an '89 A-G would run the fuel pump. Typically for earlier it's AB for codes.
Old Nov 12, 2017 | 06:58 PM
pezter22's Avatar
pezter22
I have a Autoxray CodeScout 2500, I purchased a few years ago. It reads both my C4's pretty well.
Old Nov 14, 2017 | 07:36 PM
aklim's Avatar
aklim
SnapOn MT2500 or go buy the OBD 1 scanner at Autozone and see if it reads your car. IIRC AutoXray was bought over by another company but it didn't support my 91. I'm going to buy another one to try and if it doesn't work, return. I'd get the more expensive ones if I can so it reads both OBD1 and OBD2
To Engine code readers
