Fuel Injector Cleaner
What problem or issue are you attempting to solve? None? Then I'd recommend "neither". I wouldn't buy and pour dubious potions into any of your car's orifices...and I wouldn't remove injectors to pay to have them serviced. You realize that all pump gas already has detergent in it right? That that detergent is there specifically to clean (or keep clean) your injectors? If the car runs fine, makes fine power, and gets fine gas mileage...you're hitting the metrics and that means the car is working right. Keep driving it.
"Still" implies that it was true at one time. IF you could have proven your point, I wouldn't take it personally. If you can't, which AFAIK, you didn't, why would I be upset?
Well, you asked a stupid question, I treated you with the same and due respect. What did you expect?
A. Change it now
B. Drive it till the scheduled oil change at 3000 or whatever called for
FOURSPEEDVETTE (12-29-2017)
Do you want them to figure out we use gasoline to clean carburetor's and fuel injectors?
#34
Why don't you ask others who mod their cars that dumb question? Surely GM does not condone modifying their car. Go bother them. After all, they weren't following the Almighty GM that almost got itself bankrupt so bad nobody wanted to get involved except the government who was pressured by unions.
#35
#36
If there is one thing I hate more than PSYOP games, it is the people that play them. If you are really a 15 year mechanic as you claim, I think you already know that answer. I understand it helps you project an image of really caring and being open minded, yada, yada, yada and many idiots are fooled by it. I'm not one of them. Based on your past, I see a pattern. Based on my past, you already know I would consider the MB directives as a STARTING POINT and the GM manual, not worthy of wiping my ***.
#37
I know you don't follow GM service procedures. I thought if you had a better way of dealing with injector issues then you might want to talk about it. The friendly post is not a game. I guess your not ready for that. Have a nice day.
#39
I mean GM almost paid most of it back.
#40
