Smog pump
Smog pump
Not getting a lot of hits on my other post so thought I’d start one on the right topic. It appears as if it’s my smog pump making the noise. Will gutting it fix that noise or do i need to replace it or can i just eliminate it?
I'm not really the expert on that. Certainly you will need a different belt. I think different people have been dealing with that issue differently. If you find a great way to handle it, then update everyone.
https://www.ebay.com/i/182592090969?chn=ps
That is ASAP.
smog pump delete......works excellent and I used stock belt.....do it!
IDK. Last time I tried, I thought it wouldn't be able to be done without removing the AC also.
That is ASAP.
That is ASAP.
Fyi
I bought a refurbished pump because I thought mine was making noise.
The new one ran smooth. But I all had a noise.
Turns out the alternator was failing and made a similar noise.
The alternator failed on me at midnight gong home. It was a bad night. New alt no noise.
They are right next to each other.
Piece of advice. Check all options.
Btw gutting the pump is easy. If you know how to take something apart and put it back together.
I did mine with a torch. The enternals are plastic.
