Leaking C 4 roof
Leaking C 4 roof
Iknow this is an issue with most C 4 Corvettes. I have recently replaced the ECU and the car is running great. Possible old ECU part failure due to ingress of rainwater. I have spent several weeks getting the interior bone dry again. I keep the car covered with a Stormforce breathable cover which blew of the car last night during a period of high winds and heavy rain. This weather is normal during the winter months in the UK. I am sorely tempted to take the roof panel off, dry everything out and then silicone seal the roof back in position to stop a repeat of the above. I can live with the roof being non removable which to me is a price worth paying for a dry car. The roof seals look in good condition but are not doing the job, but there seems to be little point in changing them, if that probably wont cure the problem long term. Any thoughts guys?.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
If your sure its the top, You could try to remove the top and treat the seals with di-electric grease or a like product actually you should do all your seals at least once a year.
personally I would not seal the top on the car.
This is what I am referring too.
https://www.oreillyauto.com/shop/che...c-grease-18218
Thanks for that. I have used silicone grease in the past which seems to be what most of the C 4 owners in the UK use. Some of the UK owners seem to put up with the leaks and one suggested I wear a waxed jacket.Not a sensible solution. I guess some of you guys in the US don't have issues with a lot of rain. I still think a watertight roof is a must to protect the somewhat delicate electrics.
I know this may seem like an almost sinful thing to do, but, would you consider just permanently sealing the top to the body. Since I hated driving the car with the top off due to incredible amount of body shake and had water leakage issues, I finally gave up and sealed the top to the body. Its been dry ever since.
I used a professional product purchased on line that seals the windshield to the windshield frame.
i987c0sw0rth (01-16-2018)
St. Jude Donor '16
How about try using a thin foam strip 1/8x1 inch wide as a trial something that will compress well.
My '89 has a leak driver's side upper front corner that has been there since new. I have tried silicone grease, RTV under the weatherstrip to no avail. The car is stored in a hangar now, and doesn't get driven intentionally in the rain, so I'm willing to let it ride for now. Good luck on a fix.
Steve
Steve
Perhaps but if there were 10000 lottery tickets and I bought 9999, the last one would be the one that came it. Last year I plugged the slot machine. Sure it paid but overall I lost. Some asszhole came in and within a couple of spins won a huge jackpot. Can't win for losing.
Thanks guys. I think I am going to seal the top to the body. Have driven it with top off in the past but wind turbulence and noise , and vibration not a pleasant experience. Even if roof did not leak, I would not be in a hurry to take it off again.
Can be applied using a caulking gun. One tube should be enough, make sure you clean off whatever is on the mating surfaces. Can be found on-line for about $10.00 plus ship. PS there is a "Use By" date on the top of the tube. Make sure you get one before that date.
Good luck
i987c0sw0rth (01-17-2018)
If it were me, I'd use 1/8" butyl sealant. It comes in a roll. Used for campers and such. Butyl stays soft so someday you, or the next owner, can remove the top and clean it up again if you want. Urethane is great stuff, but removing it won't be so great.
OK, I have sealed the roof panel . I first took it off, cleaned everything, added a compressible self adhesive tape to the underside and re-fixed the panel in position. I then used a super duper windscreen mastic joint to seal between the top of the windscreen and the front edge of the roof panel. We have had heavy rain and snow since, but the car interior is bone dry. I know I could remove the roof panel if I wanted to, but I can't see that happening. Thanks again to all you guys for your help and advice.
