fuel pump
Old Jan 27, 2018 | 11:56 PM
ray buis's Avatar
ray buis
2nd Gear
Default fuel pump
I have 86 cor. the fuel pump has no power to it. the fuse has no power to it the relay has power to one side
Old Jan 28, 2018 | 11:29 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Have you tried a test of the relay?
Old Jan 28, 2018 | 12:20 PM
Nokones's Avatar
Nokones
Try turning the key off and back on. I believe the computer tells the fuel pump circuit to only run initially a few seconds until it starts up and requires a demand based on the data the computer receives.
You should here the pump for a few seconds when the key is first turned on.
Old Jan 28, 2018 | 04:43 PM
aklim's Avatar
aklim
To add to the confusion, you have 2 seconds of prime like you said. HOWEVER, at least on mine, if you turn it off and turn it back on, it will not prime again for a couple of minutes. It would have to have a certain amount of time before it primes.
To fuel pump
