stuck hatchback window
Old Feb 10, 2018 | 03:36 PM
soko's Avatar
soko
1st Gear
Default stuck hatchback window
1987 corvette, back window hatchback not working how can we open it
Old Feb 10, 2018 | 03:47 PM
Olsarge's Avatar
Olsarge
Ask in the C-4 forum.
Old Feb 10, 2018 | 03:49 PM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by Olsarge
Ask in the C-5 forum.
They wouldn't be able to help either since the C5 platform started in 97.
Better check the C4 forum.
Old Feb 10, 2018 | 04:33 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
C4's are not hatchbacks.
Old Feb 10, 2018 | 06:53 PM
ColaBear's Avatar
ColaBear
2018 C1 of Year Finalis4
I found this on another form.
It is under the rear hatch trim,just to the passenger side of the latch assembly. It is a small cable tucked under the trim. You will have to feel around for the cable under the trim piece.
Old Feb 10, 2018 | 07:52 PM
Olsarge's Avatar
Olsarge
Guess I didn't correct myself quickly enough.
Old Feb 10, 2018 | 09:43 PM
RUU's Avatar
RUU
Old Feb 12, 2018 | 02:39 PM
c4cruiser's Avatar
c4cruiser
It is under the rear hatch trim, just to the passenger side of the latch assembly. It is a small cable tucked under the trim. You will have to feel around for the cable under the trim piece.
The cable is fairly short, but you should be able to grab it and pull back towards you. It will help to have somebody press down on the glass by the two round covers so that the lock will open easier.
Once the hatch is open, you can access the hatch relay by removing the U-shaped trim piece. Did you check the fuse panel for a blown fuse? Basic electrical troubleshooting should find the cause of the problem.
Old Feb 14, 2018 | 11:38 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
What do you call them?
Old Feb 14, 2018 | 02:17 PM
383vett's Avatar
383vett
Op, does the solenoid click when you hit the release buttons? Have you checked the fuse?
To stuck hatchback window
