Disconnecting antenna on a 1992 Convertible?
#41
I had to pull the carpet over the wheel well in order to locate the antenna relay. Now that I know where it is, it's not even necessary to move it. Just fold back the carpet flap in the back corner.
#42
The harness/connector for a '92 vert is under the carpet in the rear (dare i say Cargo area) of the drivers side (back in the corner by the speaker) just peel back the corner of the carpet and dig around
(as I'm typing this there was a GREAT photo uploaded...)
also a good note if you do disconnect it, there is actually a difference in reception once you get out of metro areas so i would suggest disconnecting it in the "up" position (providing the appearance doesn't bother you)
