Door chime, light switch replace
Old Mar 6, 2018 | 03:07 PM
xrav22's Avatar
xrav22
Default Door chime, light switch replace
Having trouble finding out if anything will fall behind my fender.
My left side lights and hatch trigger(the metal one) needs cleaning.
Has anyone unscrewed it without difficulty.
I cant find any info on replacement but it looks pretty straightforward.
Thx
Old Mar 10, 2018 | 03:19 PM
Smokeysvette's Avatar
Smokeysvette
Here check this thread: https://www.corvetteforum.com/forums...tch-maybe.html
Old Mar 11, 2018 | 09:14 AM
WVZR-1's Avatar
WVZR-1
If you happen to pull the wires from the switch when you remove it from the hinge pillar there's a hole on the inside of the pillar where you can reach to retrieve/put hands on the wiring. I've never needed to retrieve but if you know where G201 ground is the hole is in the vicinity. You might try the hole for hand size before you start.
To Door chime, light switch replace
