Monospring condition
Old Mar 15, 2018 | 12:01 PM
DGXR's Avatar
DGXR
What causes the transverse springs to crack and delaminate like this? Road hazard impact? Heat from exhaust? Other?
Old Mar 15, 2018 | 03:53 PM
vette196's Avatar
vette196
Originally Posted by WVZR-1
What year is your car? There's 3 style front springs, through '87 and then 2 styles for the '88+. I'm quite sure I have both later style fronts with 20K miles. I would need to check codes. I have 2 rears - one is a 20K match to the front and the other is from a purchase I did of several rears and assorted parts a fellow had for spares for a Hot Rod. It was sold to him as 'new'!! It's certainly pretty!
I took a look at the build sheet and its says FE1, which is the base suspension
Old Mar 15, 2018 | 05:29 PM
WVZR-1's Avatar
WVZR-1
You mentioned 'build sheet' - do you actually mean maybe SPID label in the car? The actual 'build sheet' would have spring codes. I'm going to look this evening again for that spring. I called a friend who might have it and he says NOT so .......................
Old Mar 15, 2018 | 05:33 PM
vette196's Avatar
vette196
I meant the RPO codes that are in the compartment behind the passenger seat
Old Mar 15, 2018 | 05:39 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
I have a pair of springs out of a 96. front-fha, rear-nyr.
Old Mar 15, 2018 | 06:03 PM
WVZR-1's Avatar
WVZR-1
Your '96 looks like my snapshot on each end? 1 1/4 square pad 3/4 tall best I recall is quite close.
OP - buy these!!
Old Mar 15, 2018 | 10:37 PM
Sleazy Rider
OP - buy these!!
Attachment 48264051
that is what my spring looks like.
Old Mar 16, 2018 | 09:45 AM
vette196's Avatar
vette196
Where are those markings? Could they be on the side of the spring that I can't see until I remove them
Old Mar 16, 2018 | 11:45 AM
vette196's Avatar
vette196
I PM'ed you but haven't heard back.
Old Mar 16, 2018 | 04:33 PM
Sleazy Rider
sorry, but there are no pm's in my box from you. I can send you some pictures of the springs.
