Premium or regular?
Old Apr 12, 2018 | 04:57 PM
  #101
aklim's Avatar
aklim
Originally Posted by cdm747
It appears in this article that it is not just the frequency but the intensity (loudness) that creates a varying voltage by the knock sensor. Much like a tuning fork will always vibrate at a specific frequency when struck. The difference that you can hear is that when you hit with a hard object, more energy is transferred in the impact, making it ring louder, but with the same frequency.
https://www.azosensors.com/article.aspx?ArticleID=50
Perhaps you are in the right direction. It has to have a certain intensity BUT also fall in that frequency spectrum otherwise it doesn't register. Makes sense otherwise it may pick up all kinds of engine and road noise.
Old Apr 12, 2018 | 06:29 PM
  #102
84 4+3's Avatar
84 4+3
I would guess a metal screwdriver is close to something knocking on a bearing... Metal on Metal and such.
Old Apr 14, 2018 | 05:54 PM
  #103
AirForceOne!'s Avatar
AirForceOne!
I've been running premium gas with 10%methanol for 6 years now and never had any problems what-so ever
Old Apr 15, 2018 | 05:58 AM
  #104
kenmohr's Avatar
kenmohr
me too! since 2007
Old Apr 19, 2018 | 01:58 PM
  #105
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Renfield
I have no interest in running 87 octane in my Vette. Why reinvent the wheel? I am quite satisfied with the conclusions documented in the quoted article.
Originally Posted by Tom400CFI
I'll probably test on my car anyway because I like to seek fact.
Finally got around to doing a little looking. This is on a '92 LT1, 85 octane -the "cheapest"/"worst" you can get. All photos were taken when climbing a hill, and in a high gear; 5th or 6th gear. I was able to see/capture one knock event....
Old Apr 19, 2018 | 02:10 PM
  #106
JimLentz's Avatar
JimLentz
A working principle to piezoelectric elements involves the transmission of an electrical current in response to detecting a change in pressure or vibration by these elements. The piezoelectric element inside the knock sensor is tuned to detect the engine knock/detonation frequency.Sep 6, 2012
Old Apr 20, 2018 | 02:22 PM
  #107
RalfKramden's Avatar
RalfKramden
FWIW, the original owners manual states "Your engine is designed to operate on premium grade unleaded fuel,
However, with the electronic spark control system you may use either middle or regular grade fuel at slightly reduced acceleration performance.
Old Apr 20, 2018 | 03:18 PM
  #108
84wuzmy1st's Avatar
84wuzmy1st
I only use non-ethanol 89 Octane from Wawa in my 85.
Old Apr 20, 2018 | 06:53 PM
  #109
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
We know. The question was whether the OP could make it across the country w/o destroying his engine. I'm sort of kidding, of course he can, but would it use more fuel due to knock retard. Veteran posters here said to actually look for knock with a scanner. I did that, and basically had none. Seems like more of that "**** that ain't worth worryin' about." Especially for a guy (the OP) driving across country.
Old Apr 21, 2018 | 08:15 AM
  #110
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
Yeah - I posted that same quote from the owner's manual back in Post 26. It doesn't say it is going to hurt anything. In reality it says you can use what ever grade YOU want. Just use what makes you happy and keep on trucking.
Old Apr 21, 2018 | 08:22 PM
  #111
pologreen1's Avatar
pologreen1
Originally Posted by pologreen1
If stock it is a GM factory mass production vehicle NOT Ferrari or a custom engine! Run what you want.
It is built with the average Joe in mind that will either intentionally put the wrong gas in "cost savings genius" or not pay attention and do it.
The only thing they manufactures have not done is include an easy drain for when someone puts Diesel or Gasoline int eh wrong vehicle.
Attachment 48275982
Attachment 48275983
Attachment 48275984
Attachment 48275985
Attachment 48275986
Attachment 48275987
Nice work, Tom!
The only time higher fuel octane is an issue is
-Real old cars with leaded in mind
-Cars with high 11.0+ compression
-Forced induction
That being said if I have a vette that is stock I still would run 91-93 that is just me. A cheapskate can, will, and do get away just fine with 87.
Imagine the lawsuits, warranty claims, and issues if manufactures actually made things designed for specific use? So many of these production cars would be toast. Consumers are proven idiots, manufactures take that in to account when engineering their products.
You can always count on people trying to do something to cheat at something, what ever the context.
Old Apr 22, 2018 | 01:15 AM
  #112
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
THanks! Note that I was actually running 85 octane for this little test. On the one hadn't, I'm at high elevation -so less pressure at WOT...but the test wasn't WOT, it was regular driving, up hills mostly. Plenum pressure has to be the same, to achieve the same tq to go up a given hill, so atmosphere doesn't matter much under the conditions for this test.
Old Apr 23, 2018 | 07:36 AM
  #113
kenmohr's Avatar
kenmohr
My 2 cents. Even one knock is like hitting your valve and piston with a hammer. Premium is cheap insurance. Even though I never ever ever ever go more than 1/4 throttle.
Old Apr 23, 2018 | 07:47 AM
  #114
aklim's Avatar
aklim
If that is all you are doing, you are probably not going to hit detonation. That is over insured. OTOH, if multiple WOT runs are in your future, I would.
Old May 2, 2018 | 08:52 PM
  #115
Mr. Bear's Avatar
Mr. Bear
Originally Posted by JimLentz
Unfortunately that math doesn't work in the Chicago area as we pay a lot more for premium versus regular. Here are prices from my local gas station.
  • Regular - $2.67
  • Premium - $3.37
I wish it was only $0.20 apart around here as I would always go premium in the Corvette. It used to be much closer, but a few years ago the cost spread went up dramatically.
Thank you. I live in Md & up & down the east coast there's usually at least a $.60-$.85 per gallon difference between 87 & 93 octane. In some areas the difference is even greater. I wish I could find a 20 cent difference between 87 & 89 octanes.
