Premium or regular?
My 86 only needed 87 octane, my 88 only needed 89 octane. You should run the lowest octane possible that doesn't knock. The detergent packages at most places will be exactly the same.
The way to be sure is connect a scanner and see how many knock counts you get.
When knock is detected, the computer will pull timing until the knock counts fall below acceptable parameters. Even the LT5 with its stock 11.0:1 compression will run on 87 octane.
Performance WILL naturally suffer temporarily as result of the computer detuning in response to the higher knock counts. However(!), the computer will keep bumping (testing) the envelop and when premium fuel is reinstated to the tank, timing will be crept up until knock threshold is reached - thus restoring performance to the level of the computer's per-determined program limits.
This is why you will see "USE PREMIUM FUEL ONLY" written on the gas cap - It's NOT because the car won't run on regular, but performance detuning (via the computer) will automatically result otherwise.
So, what happens if a Vette is converted to a carb, when regular (87 octane) fuel is used after the tune was optimized for (say) 93 octane? KNOCK CITY, that's what! The timing is too advanced for the low octane fuel.
So, if ferrying a (C4) across country, assuming the computer etc. is intact, one can save some money by driving on 87 octane. And, mileage may even be a mile or so better. Just don't be so sure you could blow off a (pesky Mustang or whatever) you encounter on the expressway like you maybe used to (had you had a load of 93 octane instead of that 87 stuff)!
3,000/25 = 120 gallons
120 gallons X .25 = $30.00
Yet the "nothings-to-good-for-my-baby" crowd will ignore the obvious.
Lots of modern-ish his CAN run 87. They just knock and pull timing. My friend has a silverado ss, and it knocks going up hills on 87. It runs, but not well when load is on it.
The original injectors will fail due to ethanol...its just a matter of when.
Taking along an extra set of injectors is cheap insurance. Paying a tech to change them isn't...figure 600-800$
The knock sensors will just tell the computer to run richer/retard timing to keep the engine happy. Your MPG will go down accordingly. It might even cost MORE!
I'm not saying what the OP should run, but the knock sensor ain't gonna make it run richer, and it ain't gonna cost more either. Come on.
When we're driving in such a manner as to be concerned w/fuel economy, (driving across country) cylinder pressure isn't typically a big problem w/regard to detonation; we're running with a very small throttle opening...aren't we? Yes we are.
We're also running with some EGR. We're also running on the lowest end of the acceptable temp range (down against the stat). Under these conditions, detonation isn't typically a big problem, regardless of octane. So how are we going to get detonation, retarded timing, and lowered efficiency? We aren't very likely to. In addition to all that...how do you explain this;
"The knock sensors will just tell the computer to run richer" (?)
B/c ^That was what I was REALLY interested in hearing about.
