occasional problem starting, rough run
Just one day it was running fine, took it out for a bit, turned it off, but got back like 10 minutes later and it wouldn't start. After turning it over (more times than i should have) it started but was running extremely rough, sounded worse than a lawn mower.
After checking what i could, i saw there was oil around the valve cover at cylinder 6 and 8.
Since there was nothing i could do i left it to cool off (i guess). After some time, it had trouble starting again, but when it ran, it was fine.
When getting it back, it just died on the road, but started up again after a few minutes.
Then, after further inspection, i removed the valve covers to check the gasket, and there was a small abrasion about 3/4 inch long, enough for a slight oil leak.
im replacing the gasket just because, but i need some help here, dunno what to look into, etc (need to check plugs and wires, but that would cause the car to just die, right???)
Any codes?
My thoughts would be to next verify fuel pressure (approx 40-41 psi for the LT1,4s).
From experience, my 95 had similar issues that turned out to be an O2 sensor intermittently failing. I had to put a scanner on it and take it for a drive to catch that one!
Anywayz... See what the codes tell ya first and get back. Don't be an idiot and start tossing parts at it!
Puzzled that just a day before she was running like a top! I went in to the house for a bit and I came back out about a few hours later and she started right up again and drove great.
I came out the next day or so and she wouldn't start again then thinking OK, I'll try the "going back in the house and coming back out later thing.....LOL" (hoping it was just a glitch)
OK, She started up but ran like pure crap. and this continued on and on.
I checked the fuel pressure first and all was good with no CEL at all.
Long story short changed the opti and she's now running like she's brand new and with both of us with a big smile just tooling down the road.
BTW this was a API opti with a two year warranty through Saccity Corvette. I had "0" problems at all with them on the warranty end with only one week left on the two year warranty. They shipped me one right out with no problems at all.
My 95 LT1 coupe never gave me any trouble, opti-wise. But, as I read these C4 forums, that part gets a lot of attention.
So, I'm curious... Does anyone have data that shows opti failures by model year? I'd always heard the vented optis was the turning point, far as reliability goes. What say you experts? (I guess when I bought the Z I dodged that bullet, huh?)
PS- after the death code, i messed with the coil connectors because one is partially torn and im wondering if the problem is all starting with the bad connector. The wire is visible and it looks as if the wire itself is partially torn, thoughts?
Also, before i replaced the ICM and coil, it was only throwing H16, now its both.
