Soda Blasting NCRS CAR
I have a super mint 100% 95. There are some discoloration marks around the control arms and rear carrier. I was thinking of soda blasting those area. It is not corrosive and non gritty. Any reason not too? (also there is non visible compound that can be applied to the aluminum after blasting to keep corrosion from reforming.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Is touching the existing finish going to reduce points?
Maybe go out looking for and OEM part without the blemish?
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Clean it up using a green scratch pad and simple green
Yep, that's my go to and my parts look like yours that I can access but mine does not need disassembly and looking to get places I cant get to with pad.
Your parts look great!
Pro Mechanic
Spray on some Eagle 1 Etching Mag wheel cleaner. Let it sit for ~30 seconds, hose off. Same results as above....w/o all the time and elbow grease.
Pro Mechanic
Springs don't care. I got a drop on mine. Many drops. Didn't phase 'em.
Public service announcement. Never...EVER...get anything acidic on your Corvette Springs. It will eat through them overnight. This includes all degreasers except Simple Green. This is a well known and documented fact. If you have done it and gotten away with it, you have been lucky.
I wonder if it is just preventive, because you never know what chemical someone will try.
I recently used air compressor sprayer with laundry soap, dish soap, and simple green together. Slimy, but ate a lot of gunk off with out having to do much work.
Hope that does not hurt the aftermarket springs.
I usually used sos pads and green pads for some dirty scrubbing.
MY CAR IS FAR FROM A SHOW THOUGH.
Pro Mechanic
Also...who would leave any kind of acid on their spring "over night"? Why? The product I advocated recommends (as did I), rinsing in about 30 seconds. Overnight?
Pro Mechanic
