Driver window won't go up
Old Jun 13, 2018 | 10:33 PM
stabac's Avatar
stabac
Default Driver window won't go up
Lowering window and something went "snap" at the bottom,now window won't move. Motor works That is cable driven, correct? Will I have to replace entire regulator or can cable just be replaced.
EDIT: Jumped the gun on this post. Found replacement strap on J. B.'s, all should be well I hope. Looks like it might even be an easy job.
Old Jun 14, 2018 | 12:09 AM
stabac's Avatar
stabac
Anyone know where I could find a step by step instructions for this procedure?
Old Jun 14, 2018 | 01:58 AM
xrav22's Avatar
xrav22
I am not sure how to replace the ribbon because I replaced mine with a newer scissor style. This should work for you either way.
http://webpages.charter.net/khasting...windowreg.html
To Driver window won't go up
