Additional Theft Deterrent
Old Jun 18, 2018 | 03:26 PM
Bckmstr's Avatar
Bckmstr
I don’t see the need for it....
Old Jun 18, 2018 | 04:42 PM
DGXR's Avatar
DGXR
The idea of a "deterrent" is to give the potential thief a reason to move on. Granted, the C4 is considered by society to be "less desirable." The manual transmission is an increasingly effective deterrent as time goes on. I am fortunate that most of the places I park are decent areas, but I still use a steering wheel club when I do park in sketchy areas
But this dummy LED is kind of appealing, if I don't have to cut up my interior too much. Also the horn chirp (factory system) would lend this light even more credibility.
Not everyone has the luxury of parking in decent areas and enclosed garages 98% of the time.
Old Jun 18, 2018 | 05:15 PM
biggiefl's Avatar
biggiefl
Did you buy the faux cell phone as well? Having flashbacks to 1985.
Old Jun 18, 2018 | 05:24 PM
Whaleman's Avatar
Whaleman
Originally Posted by ihatebarkingdogs
They make 12volt LED's that are both flashing and non-flashing. The flashing LED like the OP and I have used have the flashing mechanism incorporated into the light housing.
In a 92-up, using the orange and pink wires in the center compartment, the pink is only hot in RUN (Ignition on):
orange to LED (+)
pink to LED (-)
When the ignition is OFF, the pink wire is at ground potential through other devices on the ignition circuit. The LED will be ON because it is grounded through the pink wire.
When the ignition is ON, BOTH leads of the LED are at the (+) potential, so no current flows. The LED is OFF.
Thank you very much for taking the time to write this detailed answer. I appreciate it! Dan
Old Jun 18, 2018 | 08:29 PM
B17Crew's Avatar
B17Crew
Originally Posted by C6_Racer_X
And just in case anyone here thinks they are immune, there's also this:
B17Crew
Old Jun 18, 2018 | 08:46 PM
B17Crew's Avatar
B17Crew
Originally Posted by confab
lol.. Yeah, in a world of Gen M types and automatic transmissions, a bunch of people may as well be trying to steal the USS Enterprise as a stick shift Vette.
Reminds me of a news report I heard recently. Car thief attempted to steal a car with a manual tranny. He wasn’t able to get it more than a few feet and then gave up due to not being able to drive a stick.
B17Crew
Old Jun 18, 2018 | 09:11 PM
confab's Avatar
confab
lol
Old Jun 18, 2018 | 10:58 PM
RetroGuy's Avatar
RetroGuy
Default Jus' Saying...
OK, so I was originally just posting my theft deterrent advice to be helpful in the event a thief wants to steal your Vette. I omitted it's more likely a thief would smash a side window to gain access to take something that's not attached inside your Vette. Such as a purse, backpack, briefcase, or any carrying case that looks like it could have a laptop inside. Therefore, never leave anything like that in sight. If you park outside often, the flashing LED light could help.
Old Jun 19, 2018 | 07:39 AM
aklim's Avatar
aklim
https://www.bestproducts.com/cars/au...urity-systems/
I don't think that will hack up your car if you take the time to do it right.
Old Jun 19, 2018 | 01:02 PM
C6_Racer_X's Avatar
C6_Racer_X
And if you have a convertible, it's not even likley the window will be broken.
Best strategy with a convertible is to just leave it unlocked and never leave anything easily carried inside. If you lock it, you'll come back to a cut top and whatever's easily carried that was inside will be gone.
Old Jun 19, 2018 | 01:07 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If I've ever felt the need for extra security, I've just unplugged the + coil wire.
Thieves typically don't have time to start diagnostics.
Old Jun 19, 2018 | 02:09 PM
RetroGuy's Avatar
RetroGuy
Default True!
Convertibles do get picked on. A simple 4 inch slice along the driver's side in the soft top will allow access for a slim arm or a tool to open your door from the inside. That's why I believe convertibles need a real alarm that also have motion detection and/or proximity sensors. Flashing LED light: $10. Car alarm with all the latest bells and whistles: $400.
Old Jun 19, 2018 | 02:44 PM
  #33
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Ha....you can get into a COUPE easier than that; slip your fingers into the top of the door glass...pull out on that ***** like you're goal is to break it. It won't break....but will come out far enough that you can get your arm down in there and unlock the door. You're in.
Old Jun 19, 2018 | 02:47 PM
  #34
aklim's Avatar
aklim
I own a 2008 Porsche Cayenne. I would llike to have a Remote Starter. Not a chance I'm going to TOUCH the electrical in that car. I'm bright enough to know that I don't know enough about that car's electrical system to fix it if I make a mistake, nor to even attempt the install in the first place. I also don't trust the 20-something year olds at the Porsche dealership to be able to fix my F-up either because they don't know anything more about the car's electrical system than I do. Even at $165 an hour.
I think I understand the problem now. In your opinion, there is nobody on earth capable of doing the job since you eliminated yourself and everybody at the dealership and probably private installers. As such, it is either you or nobody. I guess I'm glad I don'tt feel that way about my house. I mean, sure the plans and specifications are probably engineer approved but it is probably built by some bunch of barely high school graduates with probably a bad attitude and the roof might collapse on me some night while I am sleeping. Under that circumstance, I agree the silly blinking light that probably fools nobody except a couple of retards is the only solution if you want to DIY.
I don't disagree that I want someone competent and with an acceptable attitude to do the job. OTOH, it's just a car not a missile with a nuclear warhead that will lay waste to a major city. I have seen many an alarm system or theft deterrent installed with no issues. I don't disagree that some will have issues especially if you get some fly by night guy that does it for cash. With a reputable shop, you should be fine or at least the odds are with you.
Old Jun 19, 2018 | 03:08 PM
  #35
aklim's Avatar
aklim
Getting a good cut of steak at a nice restaurant will be over $50. You can get, at least around here, 2 breakfast sandwiches and any sized soda for about $5 at McDonnalds.
Old Jun 23, 2018 | 07:05 AM
  #36
Whaleman's Avatar
Whaleman
I ordered and received yesterday the exact same lights as the OP. They are high quality. They work just like IHATEBARKINGDOGS said they would. Not installed yet just tested on the battery. Since you get 2 I will be glad to sell my extra one for $3.00. Dan
Old Jun 23, 2018 | 10:14 AM
  #37
FAUEE's Avatar
FAUEE
Honestly, if someone wants to steal my car, they're welcome to. Its Insured, and easily replaced.
To Additional Theft Deterrent
Old Jun 23, 2018 | 10:20 AM
  #38
aklim's Avatar
aklim
Then it's upgrade time
Old Jun 23, 2018 | 12:27 PM
  #39
FAUEE's Avatar
FAUEE
They could steal any of my vehicles, they're just cars. I probably couldn't replace my C6, but I could find another car to buy.
Old Jun 23, 2018 | 02:36 PM
  #40
aklim's Avatar
aklim
There is a price tag on most anything I own. If I have to worry, why pay more for comprehensive insurance? Buy liability to satisfy legal requirements and save the rest and gain a headache.or but a more comprehensive policy and let them worry. It's all an object and replacement is easy
