Windshield washer reservoir question
What is the rubber sleeve around the supply tube at the bottom of the reservoir for? I have a leak at the bottom of the reservoir and can't see exactly where it's coming from because of it. Is it ok to remove it?
I checked my service manual and it doesn't show it, I had my lower pass. side fender piece off to clean out some junk in there and I think it's only there to protect the pump motor.
O God!...my washer just stopped working on my 85...is that where the pump is???...is it necessary to remove the fender well to get it?...haven't gotten around to check the fsm.....
Yea, it's attached to the reservoir at the bottom. 3 10mm bolts hold the unit in. Not too hard of a job.
