Hey Folks I need a Jack Puck for a 84 C4, as alway's theres a bunch of them listed and can't tell witch 1 to order ??? slotted or not and size ???
***I use a low profile H.F. Jack, could someone that's used one that does a good job please tell me where to order 1, name Link, or size and slotted or not ???
***Thank You for any Referal---would like to order today, This site is SO helpful--I do appreciate it....
*maybe even pic so I get the correct 1...
I never stood on ceremony...just bought a REAL hockey puck at a sporting goods outlet. Works good. Last long time!
Paul, Thanks I just ordered 1 NHL hockey puck 4.99 delivered, agree didn't want a "show" puck, should work fine--if not I've lost way more than 4.99 on this vette ???
Things must be getting pretty bad when you can't find a puck in Michigan. Yikes
I use a low profile H.F. jack too. I've never used ANY pucks and never will. I've yet to figure out why you need a hockey puck. (?)
Ill do ya one better..... I DONT have a LP jack and I DONT use a hockey puck!!! Been jacking up C4's since 2006 with the same jack and no pucks needed....
well as stated I ordered a hockey puck, just to have one, but since I'm changing Oil & filter & a Trans pan service tomorrow--made some 10" ramps out of some old rough cut lumber 2"x8" 5 step's=10" lift.....much nicer just driving up on ramps....
They take up a good bit of space too. I made some similar to that for my C6, back when I had it because it was all...you know....new and "sacred" or something stupid like that and I didn't want to scratch the sacred frame with a jack.
I ended up throwing the things away b/c they were so bulky, heavy and took up too much space.
Are those tapered enough that the air dam and bumper won't hit it?
Yes-they are heavy (not bad tho) BUT since I'm here alone doing any underneath work or Maint on car my intent was to be safe and not be smashed under a car till neighbors smelt the stink.
Yes they are tapered enough, and I couldn't care less about the space-VS-feeling safer under a car doing a oil change, trans pan serv, fuel filter--wich I'll be doing this morning, Hmm I didn't realize it was STUPID to not want to scratch or damage frame if it's easy Not to Damage anything, Have a great day
Yep. It was dumb. That is what I like to call: "Worryin' about chit that ain't worth worryin' about." That is one of many reasons why I don't own that car anymore...and don't miss it.
Now days, I just jack my car where Chevy says to, don't worry about it at all, and I have it on 4 jack stands in about...4 minutes.
