Need Jack Puck
Old Aug 6, 2018 | 11:39 AM
car addict's Avatar
car addict
Originally Posted by BigDogYoop
well as stated I ordered a hockey puck, just to have one, but since I'm changing Oil & filter & a Trans pan service tomorrow--made some 10" ramps out of some old rough cut lumber 2"x8" 5 step's=10" lift.....much nicer just driving up on ramps....
Had some dealings with a guy who works on Corvettes (only) for a living and has for years. In his shop he has a couple of lifts, floor jacks, and a set of ramps similar to yours. Except his are bigger and heavier. 2x10's or 2x12's, I don't remember exactly, and longer boards (more gradual climb). He said he just likes them. Quick and reliable.
Old Aug 6, 2018 | 11:44 AM
cv67's Avatar
cv67
St. Jude Donor '05
WAlmart sells a set of ramps with a gentle incline. Super sturdy and less than $40 for the pair..no need to spend a bunch.
Never heard of guys needing pucks on anything newer than a C5, just jack it up.
Old Aug 6, 2018 | 12:19 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
I have a couple small pieces of anti-fatigue mat that I stick on the cups. Sometimes just a rag. All you really need is to avoid metal on metal, at least here in Ohio where the slightest amount of bare metal turns into rust just setting.
Old Aug 6, 2018 | 01:16 PM
BigDogYoop's Avatar
BigDogYoop
Yes Indeed, used them this morning for oil & trans pan fluid, felt safe and easy, glad I made them, Thanks
Old Aug 6, 2018 | 01:19 PM
BigDogYoop's Avatar
BigDogYoop
Originally Posted by Tom400CFI
Yep. It was dumb. That is what I like to call: "Worryin' about chit that ain't worth worryin' about." That is one of many reasons why I don't own that car anymore...and don't miss it.
Now days, I just jack my car where Chevy says to, don't worry about it at all, and I have it on 4 jack stands in about...4 minutes.
Man I'm so Happy for you.
Old Aug 6, 2018 | 01:37 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Hey thanks bro! You just made my day!
Old Aug 6, 2018 | 06:15 PM
TerryOlson's Avatar
TerryOlson
Originally Posted by Paul Workman
I never stood on ceremony...just bought a REAL hockey puck at a sporting goods outlet. Works good. Last long time!
Dittos - you could buy two and cut a slot in the top one. If you've never cut a hockey puck, you won't want to do it by hand. I used hockey pucks as body mounts on a truck project and the height I needed was 1.5 hockey pucks. Cutting a puck in half with a table saw was an adventure.
Old Aug 6, 2018 | 07:02 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
So I've wondered this for a long time; if you cut a slot in the puck, that is for the pinch seam to sit in, right?
So one of the problems with jacking C4's is that on some cars, the 'glass rocker is as low, or slightly lower than the steel pinch weld (so I've read). This can cause the jack pad to damage the rocker lip. On most cars, the rocker lip is about 1 cm higher than the steel pinch weld. Wouldn't a puck either flexing (rubber) or worse, with a groove cut into it, only exacerbate the issue? I've never understood how the puck actually helps anything.
Old Aug 6, 2018 | 07:20 PM
TerryOlson's Avatar
TerryOlson
​​​​​​I see it the same way - no slot in the Puck that I use.
Old Aug 6, 2018 | 07:30 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
O.K. SO that makes more sense to me....but still...what's the puck doing that the jack pad can't do?
Bare with me...I'm slow. :-/
Old Aug 6, 2018 | 08:20 PM
BigDogYoop's Avatar
BigDogYoop
Tom, your correct-both my rockers are 1/16" below pinch weld, that's why for mean time I just made the ramps.
Old Aug 6, 2018 | 08:25 PM
TerryOlson's Avatar
TerryOlson
Nothing, I just don't have a jack pad and I use the Puck in substitute on everything!
Old Aug 7, 2018 | 09:28 AM
  #33
QCVette's Avatar
QCVette
Active Streak: 90 Days
I am another one who doesn't see the need for a puck to jack up a C4.
On C5's and later, the jacking points are masked by the rocker panels so there is no way to put a jack onto the frame without breaking the rocker panels. I use actual hockey pucks I got from a sporting goods store for my C5's.
My C4's have the rocker below the pinch welded metal, so I jack further inboard on other points. I also had one section of the pinch welded metal be slightly offset so that one of the two metal sections was lower than the other by a 1/32" or so. When I jacked there, the lower section deformed. I didn't like that, so I adjusted my jack points to further inboard.
Old Aug 7, 2018 | 10:25 AM
  #34
JBPC4's Avatar
JBPC4
I’m sure this is sacrilege to some..! But I fixed the problem of the glass rocker hanging lower than the pinch weld by cutting the low hanging part off with a utility knife! Now the glass and metal lip sit flush with each other and I can jack away with no worry of stressing the glass rocker. I figure if anyone wants to lay under my car and complain about me cutting off less than 1/4 inch of plastic/fiberglass from my car thats their issue, lol.
Old Aug 7, 2018 | 10:54 AM
  #35
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Thanks for saying that. I've never understood the puck on the C4....but I totally "Get it" for the C5^. You're right that it's virtually impossible to jack a C5^ w/o damaging something, if you don't use some kind of padding.
Old Aug 7, 2018 | 04:17 PM
  #36
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
How about some pictures?
https://www.corvetteforum.com/forums...post1593861214
