So... I’m in the process of building my 94 corvettes LT1, so far MY GOALS were 600rwhp! From what builders I’m contacting they are saying those are the limits of the LT1.
600 didn’t seem like that much to me, what are numbers being produced and what did it take to get there. Budget is around 20k for engine.
Smokey yunick used to say 600 crank hp was limit for stock sbc cast crank, but that was probably for a 5000-6000 lb truck or station wagon which your corvette is not.
so i believe > 600 crank hp is possible with stock cast sbc crank on a ‘lighter’ corvette.
forged pistons i dont think are required bc look at new supercharged or turbo engines, most dont have forged pistons anymore ! They key is engine mgt and not to detonAte. But those cars still do have forged cranks now though...
You might consider getting in touch with Tom Wong of Wong's Performance Engineering in Vancouver WA. Tom is one of the top corvette tuners on the west coast and started out in C4's
600 RWHP NA shouldn't be a problem with your budget (assuming you have another pile of cash for upgrading everything else besides the engine). Quite a few prior examples mainly F-bodies.
I seem to remember the author stating he would not try to go above 450hp or so with a stock crank, rods, & pistons. I also think he said the 2 bolt vs 4 bolt main did not make that much difference in the orig design of the LT1 block.
I have a mild mannered super charged 598 rwhp grocery getter which at this point in my life takes me to and from Disney World. An acquaintance of mine added a 100 shot of nitrous to a similar build and was pulling 722+ rwhp.
It can easily be done, but why? The heads appear to be the limitation with the Lt-1. You have the money to spend and have no investment at this point. Go with an Ls engine or build a large cube small block. Just my view if I had to do it again.
20k gets past most limitations. You will need 396 or more CI. IMO heads and intake are the tough part because of limited choices . A splade LT1 block should hold beyond the 600 you are looking for. The rest is sbc. Golden has built 700 hp NA LT1s, IDK about durability.
With that budget I'd go LS swap. Or maybe a newer (2014+) LT1 with a blower and forged everything. Why not buy a crate engine from GM that has high HP and go from there?
My thoughts exactly. Yes the original question was about the limits of the LT1 specifically. But $20k is a fat budget, so I start thinking LSX with forced induction or other tasty options. I think a new LT5 crate motor is about $18k...?
All the guys telling you to "just la swap" are nuts. That would take a LOT more time monand money, and youd end up with a half breed wacko that nobody will get near (tuner or buyers). If you want the easy route, buy a c5 and put a blower and a host of other mods on it. Or buy one already done for 15k.
Another thing, 600whp is a HUGE number. That's like 750 crank, and on an Na build would render any corvette all but undrivable. Just something to think about. I know a lot of YouTube videos and anonymous posters on forums make it seem easy and cheap, but those are for entertainment only, and most are complete lies.
