outer window sweeps
Old Aug 20, 2018 | 09:33 AM
rlg4675's Avatar
rlg4675
Default outer window sweeps
Hello, I have a 1994 Corvette base model that I am having issues with a replacement part.
I replaced the drivers side outer lower window molding/sweep (actually I purchased both sides but only installed the drivers side).
The install went smoothly but, upon rolling the window up and down I noticed a strange sticky smear on the out side of the window.
Upon inspection I discovered the inner felt strip is only attached at either end with rivets but the center is glued on.
When the window is rolled down the felt rolls up in the center and visa versa on rolling the window up, leaving a sticky smear of adhesive on the window surface.
I contacted the seller and they sent out a new one but upon inspection it has the same flaw.
The seller refunded my money but now I am searching for a better replacement.
I bought these from a corvette specialty parts and accessories shop. I also contacted a different seller but they couldn't tell me if their part has the felt attached in the same way.
Does anyone one have a source for a better part?
Thank you
Old Aug 20, 2018 | 10:10 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Its been a long time ago I ran into the same problem.
I removed the felt and sticky stuff. Using the "loop" side of some velcro I had laying around rewrapped the guide.
Worked!
Old Aug 20, 2018 | 06:35 PM
confab's Avatar
confab
Mine is older, but I drilled a hole in the middle and riveted it to the door.
Old Aug 22, 2018 | 12:08 AM
rlg4675's Avatar
rlg4675
I thought of doing that but the edges appear to still roll up when the window moves..
Old Aug 23, 2018 | 10:58 PM
stabac's Avatar
stabac
Won't solve your problem but I found Mr Clean white pads remove everything off the windows... bugs, grease, wax, film...squeaky clean.
Old Aug 24, 2018 | 01:05 AM
ChumpVette's Avatar
ChumpVette
Get rid of the cheap sweeps and get a quality product that uses pop rivets all the way across like the factory used.
Old Aug 24, 2018 | 01:57 AM
rlg4675's Avatar
rlg4675
Yes that is what I am looking to do, the ones I purchased were from a Corvette specialty parts and accessories shop. I am looking for better quality part than the ones I purchased.
I have called several corvette parts houses and none can tell me how the felt pad is attached.
Old Aug 24, 2018 | 07:38 AM
AirForceOne!'s Avatar
AirForceOne!
Just had mine replaced with these ones from Davies Corvette, excellent quality! . You have to get the pop rivets separately for $2.00
https://corvetteparts.com/item/sealing-strip-pair-outer-door-glass-with-felt-1984-1996
https://corvetteparts.com/item/rivet...ning-1984-1996
Old Aug 24, 2018 | 09:01 AM
rlg4675's Avatar
rlg4675
Thank you ,I truly appreciate your reply and links.
Thank you to everyone who answered my post.
To outer window sweeps
