low coolant light
Old Aug 26, 2018 | 04:38 PM
1972bluelt1's Avatar
1972bluelt1
Default low coolant light
My 89 L98 has an intermittent low coolant light. It doesn't over heat. The coolant isn't low when I check it cold and there's coolant in the overflow tank.
Also I just replaced the sending unit, which made no difference. Anyone else have this problem?
Old Aug 26, 2018 | 06:25 PM
Whaleman's Avatar
Whaleman
I am not an expert by any means but if you are sure it is full and you just replaced the sensor only two things can be wrong. The new sensor is bad or the wiring has some kind of short. There may be other things that are way over my head. Dan
Old Aug 26, 2018 | 08:07 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
My gut teels me you have air in the system as the light is intermittent. The sensor is binary in operation and will read off/coolant, on/no-coolant. When the water drops below the sensor, it tells the sensor to turn on the light.
In order to get that light to stay out, you have to make sure that ALL of the air is out of the system. I'd wait till cool and then open the radiator cap and start the engine. When you rev the engine, the water level drops and then you want to add fluid. When you let up on the idle the water comes to the top. Put the cap back on as the excess will flow into the over flow tank.
Old Aug 27, 2018 | 06:08 AM
kenmohr's Avatar
kenmohr
Can also be radiator cap or head gasket.
Old Aug 27, 2018 | 06:48 AM
AirForceOne!'s Avatar
AirForceOne!
Mine was the radiator cap!
haxxx's Avatar
haxxx
If you had that much air in the system, I would think after running the car hot for a while the car would boil the coolant and puke it back out into the lower clear reservoir (guess how I know). Try bleeding the system first.
If not the sensor is broken. GM likes to use a simple float sensor. They do get gummed up sometimes and/or mysteriously break. I've had intermittent coolant lights on other GM vehicles until the sensor goes completely. The sensor is part of the black assembly at the top with the metal cap. Not sure if you can just replace the sensor or if you have to replace the whole assembly.
Old Aug 27, 2018 | 06:22 PM
Whaleman's Avatar
Whaleman
Originally Posted by ihatebarkingdogs
86-90 Corvette does not "use a float". The sensor is a simple probe into the radiator tank. There is a module that reads resistance on this probe to ground through the coolant. Something like less than 10,000 or over 25,000 ohms is Not OK, but within that range IS OK.. It is a range, not an absolute value, so it is not "binary". (I'm sure these numbers are not accurate, I don't recall the values offhand, this is for illustration). Many things can affect the resistance measured at the probe. Glycol concentration, mineral content of make-up water, air (as mentioned). There is also a time-delay between the sensor detecting an out of range condition and turning on the light. So "air bubbles" shouldn't affect the reading, unless there is a large void in coolant. Keep in mind that at cruise conditions, the thermostat is the biggest restriction to flow. The radiator will "empty" to keep the engine full, pressure drops after the thermostat, so the radiator level will drop even though the engine temperature remains within operating range..
I have seen radiator probes that have corroded away so that only the diameter of the probe is exposed to coolant, thus sending high resistance and a false-low indication. The probe used to be available separately from GM. I have no idea if it is any longer. The probe is retained in the radiator tank with two plastic clip/latches, and sealed with an o-ring. It just pulls out.
If you are certain that coolant level is adequate, you probably have a corroded probe. I'd attempt to source a new one before removing the old one. You can't just disconnect the probe to turn out the light because of the "range" of resistance expected.. You have to insert the expected resistance in the probe circuit, or remove the dash pad and disconnect the module. It's on the RH side behind the breadloaf.
In the first post he said he just replaced the sensor. Could he have got the wrong one? Dan
Old Aug 27, 2018 | 10:55 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Unplug the sensor and connect the plug wire to ground. The low coolant lite should go out.
My 86 would get fiesty after a coolant change. So knowing that the system was packed and full I'd do this for a day or two then connect it back to the sensor.
Always worked for me.. YMMV
Old Aug 31, 2018 | 08:18 AM
1972bluelt1
Mine was always finicky after a coolant change also. Ordered a new cap from Rock Auto (no one in town had an AC Delco).
Can't remember if I ever changed it. My LS1 Firebird did a lot of gurgling after I shut it off, a new cap fixed that.
Old Sep 24, 2018 | 08:32 PM
StephenC46's Avatar
StephenC46
2nd Gear
86-89 Corvette does not "use a float". The sensor is a simple probe into the radiator tank. There is a module that reads resistance on this probe to ground through the coolant. Less than 10,000 is OK, over 30,000 ohms is not OK and will trigger Low Coolant.. It is a range, not an absolute value, so it is not "binary". Many things can affect the resistance measured at the probe. Glycol concentration, mineral content of make-up water, air (as mentioned). There is also a time-delay between the sensor detecting an out of range condition and turning on the light. So "air bubbles" shouldn't affect the reading, unless there is a large void in coolant. Keep in mind that at cruise conditions, the thermostat is the biggest restriction to flow. The radiator will "empty" to keep the engine full, pressure drops after the thermostat, so the radiator level will drop even though the engine temperature remains within operating range..
I just bought a new sensor and tried to install in an aftermarket Aluminum radiator. How much force is required to push it in?
I tried and it won't go. I white lubed it a little, as well. I don't want to brek it. By the way, the sensors are available through NAPA.
Old Sep 24, 2018 | 10:31 PM
JrRifleCoach
I had to lightly file the tangs on the radiator just a smidge for the cap to seat.
To low coolant light
