Tachometer
Old Oct 24, 2018 | 06:16 PM
Pyepye's Avatar
Pyepye
Default Tachometer
My tach is haywaire on my 91 c4 6sp conv.
I know thw fix is replacing a bad resister behind the guages, but I opted to add an after market tachometer instead.
So here is my question. I am feeding the new Tach with the single wire that comes off the negative side of the ignition coil. It works great....can I clip the wire going to my in dash tach without affecting anything else? Or does that single wire aslo provide information to the computer...?
Am I doing something wrong on this site, I seldom get answers or maybe I just dont know how to use the site?
Carl.. Thanks for any help....
Old Oct 24, 2018 | 10:28 PM
car addict's Avatar
car addict
Old Oct 24, 2018 | 10:33 PM
jv9999's Avatar
jv9999
Yes you can. The ECM gets a different RPM signal from the tach harness.
Old Oct 24, 2018 | 10:35 PM
PatternDayTrader's Avatar
PatternDayTrader
You mean to cut it so you can connect it to the aftermarket tach ? Is that what you mean ?
If so, I cant think of any reason why this would be a problem, but you could just splice into it by stripping the insulation and soldering in a section to connect to the aftermarket unit; that way, if you ever fix the original and want to remove the aftermarket unit, you just cut that wire and tape it off and your done.
Old Oct 26, 2018 | 05:31 AM
Paul Workman's Avatar
Paul Workman
I installed a new resistor and a 1k ohm potentiometer (to determine the best resistance value). It cost under $5 total in parts and start to finish was around 2 hours or so.
Batee sells the voltage divider to replace to bad one which would cut the time to repair considerably. I'd guess their part would cost only a few $, but waaay less than an aftermarket tach.
So... I hope you have another reason to replace the stock tach with some add-on tach.
Old Nov 16, 2018 | 04:37 PM
Pyepye's Avatar
Pyepye
No, no other reason other than I just did not want tear the dash apart. Sounds like its an easier job than I thought. I definitely want to fix it correctly, but for now the after market tach works 4.0
Thanks for the gouge......
PyePye
Old Nov 19, 2018 | 04:45 AM
CVG323's Avatar
CVG323
Pictures of the tach please
To Tachometer
