Help
Old Oct 27, 2002 | 05:26 PM
CuVette's Avatar
CuVette
Cruise-In III Veteran
Default Help
Something got triggered on the doors and they won't come out of the lock position....what do I do??????????? I can't close the doors!
Old Oct 27, 2002 | 05:28 PM
STREETKNIGHT's Avatar
STREETKNIGHT
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Help (CuVette)
Both of them?
Old Oct 27, 2002 | 06:21 PM
minnasotajim's Avatar
minnasotajim
If elec try disconnecting the battery to see if they reset
Old Oct 27, 2002 | 07:36 PM
STREETKNIGHT
Did you get it unstuck? :confused:
Old Oct 27, 2002 | 09:28 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
Hey Amy, sometimes you got to giggle it with your fingers and they will work loose.
Old Oct 28, 2002 | 01:17 AM
GDP's Avatar
GDP
It might be the temperature. On my dad's Z71 Tahoe and my mom's Suburban when it gets really hot (that is, Texas heat) sometimes the locks won't unlock all the way and they must be undone manually from the inside. Also, sometimes when it gets really hot the rear passenger door on the Suburban won't shut. Like the latch on the door doesn't click back all the way. It's rather strange. Could this be the culprit? It's fall and if you live in a hot climate the sudden temperature change might have caused it. Just a guess. Hope everything works out. :cheers:
[Modified by GDP, 11:18 PM 10/27/2002]
Old Oct 28, 2002 | 01:28 AM
AlwaysWave's Avatar
AlwaysWave
Thanks guys :) Problem fixed.
Both doors went nuts. Amy opened the drivers door to trigger the rear hatch, and the actual door mechanism went up into a lock position not allowing the door to close. I opened the passenger door to get a visual of an "ok" lock and that one did the same thing :eek: Weird.
Anyway, I found that there is a pawl up above the rotating mechanism that locks them in place. By using a screwdriver I was able to move that spring loaded pawl up and rotate the actual lock portion down. They both work fine now.
What's unexplained is why and what caused it to happen to begin with? Halloween spooks? :confused:
To Help
