Sinking shift indicator fix
Old Nov 14, 2018 | 08:40 AM
Renfield's Avatar
Renfield
Default Sinking shift indicator fix
When I bought my '96, the shift indicator panel that is screwed to the underside of the console was floating loose. Worked fine, but flopped around a bit. On removal I discovered the reason: broken plastic studs with metal tips for the screws.
I used drywall screw parts and plastic epoxy to recreate a new place to affix the screws.
It's a small thing, but in my case the loose panel was wearing a short into the wires for the lighting and my dash lights were blowing a fuse.
If your display droops, it's a pretty easy fix.
Measure carefully and cut to the desired depth.
It's what they had at autozone.
The epoxy sets up creme colored
After...
It's what I had in the pantry.
Old Nov 14, 2018 | 09:15 AM
PatternDayTrader's Avatar
PatternDayTrader
Found a short in the lighting circuit ?
Electrical work doesn't get much more difficult than that.
Well done.
Old Dec 15, 2018 | 10:12 AM
Renfield's Avatar
Renfield
Well done.
Thanks. It was pretty obvious where the pinch was occurring. Obvious is right up my alley.
Judging by the crickets chirping softly, I guess I'm the only one with a sagging indicator. Or are folks just buying a whole new console cover? That would address the Dulso issue as well. I'm not replacing anything I can repair on this old chevy.
Anyway, so far the epoxy is working much better than the hot glue I tried before.
Old Dec 15, 2018 | 10:31 AM
Whaleman's Avatar
Whaleman
Please do not sell yourself short. I just had the same problem in my 96. I used your method and it worked great. I did come to the conclusion the rear broke just like yours after the front screw fell out. Thanks, Dan
Old Dec 15, 2018 | 10:45 AM
Renfield's Avatar
Renfield
Nice. Glad to read it worked for you too.
All the best
George
Old Dec 15, 2018 | 03:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Such little "fixes" are part of the fun of ownership, IMO.
To Sinking shift indicator fix
