1994 Z07 production numbers
Old 11-15-2018, 10:26 AM
Brooks94Z07
Support Corvetteforum!
Brooks94Z07's Avatar
Default 1994 Z07 production numbers
So I guess I just realized today that my new 1994 Corvette purchase actually is the Z07 package, which I did not know/knew nothing about at the time of purchase.
How many Z07s were built in 1994 with the ZF transmission ?
What else can you guys tell me about the Z07?
Thanks!
Old 11-15-2018, 12:41 PM
Mr. Peabody
Mr. Peabody's Avatar
C4 of Year Finalist (appearance mods) 2019
According to the Corvette Black Book 887 cars were built that included the Z07 option. They don't break it down by combinations of options but approx 1/4 of the entire 1994 run was with the 6 speed trans.
Old 11-15-2018, 01:08 PM
c4cruiser
c4cruiser's Avatar
RPO Z07 first appeared in 1991 replacing the Z51 suspension package. It was available with either the manual or auto trans but was a couple only option. The option numbers varied up thru the 1995 cars but typically was around 750-800 units installed on the coupes. Typical cost for Z07 was around $2200 Z07 included the FX3 adjustable shocks with all the other heavy duty suspension components. Larger HD brakes (J55 package) were also included.
Old 11-15-2018, 04:19 PM
Fiberbundle
Fiberbundle's Avatar
Spring rates on the ZO7 are 50% higher than the base model and 24% higher than on the ZR1 (and you will feel it if you have rough roads). Also 30 mm solid steel front sway bar replaced the 24mm tubular on the base and 26mm tubular on the ZR1. You may also have a slightly quicker steering ratio (earlier ones did but they may have all gone to the quicker ratio by 1994). Also earlier models had slightly thicker control arms and slightly different bushing compound not sure on 94. My 92 is 1 of 738 with only 21,700 miles. Does not add anything to the value but nice if you decide to take it to the track.
Old 11-15-2018, 04:23 PM
Fiberbundle
Also production of the ZO7 for 1994 was 887 units.
Old 11-15-2018, 05:13 PM
1993C4LT1
1993C4LT1's Avatar
Z07s rule.
Old 11-15-2018, 06:56 PM
Brooks94Z07
Wow thanks for the info everyone.
At first, I was hesitant with the seller because of the wheels not being staggered as I thought that was always a standard on every Corvette (c4s at least) and just seemed fishy to me..
So glad I decided on making the buy..for $5k!
Old 11-15-2018, 07:04 PM
1993C4LT1
1993C4LT1's Avatar
How many miles?
Old 11-15-2018, 07:17 PM
Brooks94Z07
150k
Old 11-15-2018, 07:56 PM
Mr. Peabody
Welcome to the world of C4!
Well, a lot will depend on how it was maintained over its life. Having the 9.5 at all 4 corners is no problem at all and .... we get to rotate tires from front to back.
It's kind of mandatory .... you have to post pictures
Old 11-15-2018, 08:33 PM
Brooks94Z07
I've been talking about my new purchase in a couple places
https://www.corvetteforum.com/forums...-question.html
https://www.corvetteforum.com/forums...-c4-owner.html
Old 11-16-2018, 07:49 PM
9T3VETTE
9T3VETTE's Avatar
Not to hijak but any idea how many 93 40th anniversary Z07 (6 speed if it matters) were built? I’ve always wondered
Old 11-16-2018, 07:50 PM
9T3VETTE
9T3VETTE's Avatar
Btw to the OP it’s a great car you are going to enjoy it!
Old 11-16-2018, 09:53 PM
1993C4LT1
1993C4LT1's Avatar
I would try and find out how many z07 rubys were made, when I had mine. Could never find answer.
Old 11-17-2018, 01:59 PM
Fiberbundle
824 ZO7 and 6,749 Rubys but no way to tell how many had both. Someone with better access to info at Bowling Green might be able to find out.
Old 11-17-2018, 06:52 PM
9T3VETTE
9T3VETTE's Avatar
more info than I ever had. Thanks!
Old 09-15-2019, 07:54 PM
LT4 F45
LT4 F45's Avatar
93 40th anniversary Z07 6 speed 145
93 40th anniversary Z07 Automatic 193
To 1994 Z07 production numbers
Old 09-16-2019, 01:06 PM
KyC4-94
KyC4-94's Avatar
I got my first C4 a month ago and it is a 94. How can i check if mine has this option? Thanks in advance.
Old 09-17-2019, 09:14 AM
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Old 09-18-2019, 07:06 PM
LT4 F45
LT4 F45's Avatar
Thanks!
397 6 Speed and 390 Automatic's Z07 produced in 1994
Color of your Corvette?
Quick Reply: 1994 Z07 production numbers
