New LED headlights
Those LED retrofits range from truly horrifying to merely dangerous and annoying. As I stated above, the danger is more to yourself than to other vehicles. They are annoying to other vehicles, but the accidents I've seen with those setups at night have all been single car accidents, usually with significant damage (often total loss damage) to the vehicle with the LED "Conversion" lights.
just installed my AMAZON $53 set.
wow what a diff. from stock!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I would send those back and get the ones I posted. You wont regret it.
These are what I had before this latest set. These 90 dollar ones are worth every extra dollar over them. They're brighter, put the light in more useful places, throw a wider pattern, and give off less glare.
Thanks in advance .
These are the headlights in low beam mode.
CVG323 (12-19-2018)
And this is with the high beams on.
CVG323 (12-19-2018)
I have decided i have one complaint, which isnt too bad i guess. I wish i could aim them a bit higher. Theyre maxed out in height adjuztment, i would go higher if i could. I might try to replace the adjustment screws with something longer...
Then you own it. Sorry to say. I'd use that to test but for final install, I'd cut the car side and solder with heat shrink if I were to do that. Before you return everything, why don't you try to use the plug in ones and see if it works? That is the route I took. If it didn't work everything is returned.
#37
Hello,
I'm interested in getting a set of these for my 91 vert, when I type in the info it comes up with headlamps for Jeep wranglers, are the for both vehicles?
